InductionHeater
| Project InductionHeater | |
| Status | Initializing |
| Contact | smeding, gori |
| Last Update | 2014-09-08 |
Idea is to make a 3kW induction spool to smelt metals and heat steel for forging. For examples see :
Inverter circuit
Smeding came up with the following circuit:
Values of all components are to follow shortly. The accompanying BOM looks something like this:
| Component | cost |
| Bridge rectifier | €2.56 |
| switching transistor | €22.92 |
| Tank capacitors | 20.50 |
| DC link filter capacitor | €23.14 |
| Gate driver | €7.06 |
| Couple transformer Toroid | €20 (est.) |
| Gate drive transormer toroid | €3 |
| Estimate for components killed (see below) | €60 |
| Total | €160 |
Based on Smedings estimate Obviously, some parts may die a gruesome death during construction and testing. Worst case estimate is that the switching transistor and the driver will die twice, adding an amount of €60 to the BOM before we have a working machine.
Additional hardware
In addition to the inverter circuit, at least the following things are needed to make a working induction heater
| Component | cost | Possible sources | requirements |
| Coil 1 small diameter for smelting | € 15 ? | Gas tubing, car brake tubing | Copper. Sufficient copper area to handle the current. Sufficient inner area + diameter to allow for effective cooling |
| Coil 2 large diameter, 30cm for forging, between 5 and 10m | € 25 - 50 | Gas tubing, 15 mm car brake tubing | Copper. Sufficient copper area to handle the current. Sufficient inner area + diameter to allow for effective cooling |
| heat exchanger | €15 ? | Car junkyard | Unsure how much heat needs to be removed and at what temperatures. Worst Case would be 3 kW. A car radiator is probably good (cheap, sufficient power and an integrated fan) |
| Pump | €20 | Possibly a pump from a domestic heater (CV). Buy for around €20 on Marktplaats | Have to check whether or not normal sizes create sufficient flow through small diameter coil tubing |
| Electrical connections and wiring | € 20 | Battery connections form scrapped cars? | How much current do we expect, and how long do the wires have to be? how do we connect these to the coil tubing (Earth blocks? |
| Tubes and other cooling connectors | 15€ | ||
| Total cost | € 85 (incomplete) |
Total cost
| cost | |
| Inverter | €160 |
| Hardware | €85 |
| Total | €245 |
Now we need financing. The current total is €245, and that isn't complete so far (although it may get close)
Pledges:
