CO2MeterHacking
Versie door Bertrik Sikken (overleg | bijdragen) op 18 mrt 2014 om 17:09 (Add image)
Project CO2MeterHacking
Status Initializing
Last Update 2014-03-18
This project is about hacking the Voltcraft CO-100 CO2-sensor, such that we can read the exact ppm value as displayed on the LCD.
This particular CO2-sensor is present in the klusbunker at RevSpace and is currently used to control the ventilation in a crude manner (by monitoring the warning LEDs on the display module). Having the CO2 ppm value available as a number allows for nice things such as logging the levels over time, announce them on IRC, show them on the LedBanner , etc.
The user manual of the Voltcraft CO-100 says "Attention! The RJ45 connection (see chapter 7, item „K“) must not be used. The connection is only intended for the manufacturer". Of course, a claim like that can only be interpreted as a challenge! :)
Investigation
The CO2 sensor at RevSpace has a sticker saying ZGw063RY. Googling for this number reveals a CO2 sensor that looks just like the Voltcraft CO-100, so it appears that the CO-100 is basically just a rebranded ZyAura ZGw063RY module.
Unfortunately, the sensor module inside the CO-100 does not look like a Telaire TL-XXXX or a MH-Z14 (for which there *is* some documentation of the protocol available).
Also, the CO2 meter at RevSpace seems to miss a bunch of components that can be mounted on the PCB, close to the RJ45 connection (possibly an RS232 chip with step-up capacitors).
CO-100 internals
