Its-g5
Project ITS-G5
Receiving ITS-G5 signals
Last Update 2026-07-30
wireshark analysis
Stuff to investigate:
Design
esp32-c5-sniffer
The design is:
  • Use an esp32-c5 for sniffing 802.11p frames only
  • Use an esp32-c3 for receiving sniffed frames from the esp32-c5, connect to WiFi and upload packets over MQTT
  • The interface beteween the two boards is serial, this is simpler than SPI as used in other projects:
    • Only three wires required: GND, +5V and serial DATA
    • No hardware modification required (e.g. desolder capacitors on SPI wires of the esp32-c5)
    • A serial interface is more universal, e.g. can be connected to an arbitrary linux SBC, to run a python bridge for example
    • On the esp32-c5 use the same wires as the existing USB-UART bridge, so you can also receive packets over USB-serial
  • Run a simple web server on the esp-c3:
    • Configuration page with MQTT settings: protocol, host, port, user, pass
    • Optional: show some nice stats: mqtt status, packet rate, last packet, packets per type
    • Optional: run a very basic parser for e.g. CAM messages
  • Power is provided to the esp32-c3, which then distributes power as raw 5V/GND to the esp32-c5. The esp32-c5 uses its own regulator to turn it into a stable internal supply voltage.
Practical:
  • The serial link runs over the USB-UART chip of the esp32-c5.
  • A simple command processor runs on the other UART (the emulated USB serial port)
  • On the esp32-c5 side, use pins GND, 5V, UART-TX for the ESP-ESP serial connection.
  • The esp32-c3 and esp32-c5 share their 5V and GND power lines. Each board derives its own internal power supplies from this 5V.
  • The serial link doesn't have to be very high speed, 115200 for example. We use a hardware UART on both sides of the serial link.
  • Use https://registry.platformio.org/libraries/thomasfredericks/MicroSlip for framing packets over the serial port.
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
See also https://github.com/pit711/v2x2map/blob/main/firmware/main/mqtt.c
In short: server = mqtts://cits1.opentrafficmap.org:8883 :
  • no user name / password
  • topic 'its/<node>/status' (online or offline), retained
  • topic 'its/<node>/info' with a JSON string, like {"emac":"xx:xx:xx:xx:xx:xx","ver":"github.com/bertrik/its-g5-receiver-v0.0.1","hwv":"esp32-c5-devkit-c1"}
  • topic 'its/<node>/packet' for sniffed packets (raw, not JSON encoded)
Sniffer
esp32-c5
esp32-c3
This project uses an ESP32-C5-devkitC-1 board for the sniffer part:
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Bridge
An ESP32-C3 is used as the bridge part. I used a 'supermini'.
How to wire it up, what I did:
  • Put both the esp32-c3-supermini board and the esp32-c5-devkit-c1 on a breadboard
  • Use male-male dupont wires to connect:
    • 5V to 5V, GND to GND, esp32-c5 TX to esp32-c3 RX
  • Programmed the esp32-c5 with firmware
  • Plug an USB-C cable into the esp32-c3, programmed it with firmware, now it's powering both the esp32-c3 and the esp32-c5
The esp32-c3 supermini apparently has a design flaw causing them to run very hot:
So in software you need to keep this in mind:
  • lower the CPU frequency, makes a few degrees difference: this seems to make SSL network connections unreliable though
  • allow some 'idle' time in Arduino, e.g. using delay(50) or delay(100) in loop()
Connections
ESP32-c5 ESP32-c3 Remark
GND GND shared ground
5V 5V raw power
U0TXD/GPIO11 RX/GPIO20 Data link
See https://github.com/bertrik/its-g5-receiver
This is heavily inspired by https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware but with a fixed size ring buffer instead of dynamic allocation.
Compiling the firmware
Uses python and platformio, see the README.md in the source archive.
Watch packets come in:
 pio device monitor
Then viewed in wireshark:
 wireshark message.pcap
