Its-g5
Revision as of 21:18, 28 June 2026 by Bertrik Sikken (talk | contribs) (Software)
Project ITS-G5
Investigating ITS-G5 signals
Last Update 2026-06-28
wireshark analysis
Stuff to investigate:
Design
The plan is:
  • Use an esp32-c5 for sniffing 802.11p frames only
  • Use an esp32-c3 (as an inexpensive jellybean part) for receiving sniffed frames from the esp32-c5, connect to WiFi and upload packets over MQTT
  • The interface beteween the two boards is serial, this is simpler than SPI as used in other projects:
    • Only three wires required: GND, +5V and serial DATA
    • No need to desolder capacitors on SPI wires of the esp32-c5
    • A serial interface is more universal, e.g. can be connected to an arbitrary linux SBC, to run a python bridge for example
    • On the esp32-c5 use the same wires as the existing USB-UART bridge, so you can also receive packets over USB-serial
  • Run a simple web server on the esp-c3:
    • Configuration page with MQTT settings: host, port, user, pass, base topic
    • Perhaps configure a keystore/certificate for secure mqtt (mqtts), if needed
    • Optional: show some nice stats: mqtt status, packet rate, last packet, packets per type
    • Optional: run a very basic parser for e.g. CAM messages
Practical:
  • The serial link runs over the USB-UART chip of the esp32-c5.
  • A simple command processor runs on the other UART (the emulated USB serial port)
  • On the esp32-c5 side, use pins GND, 5V, UART-TX for the ESP-ESP serial connection.
  • The esp32-c3 and esp32-c5 share their 5V and GND power lines. Each board derives its own internal power supplies from this 5V.
  • The serial link doesn't have to be very high speed, 115200 for example. We use a hardware UART on both sides of the serial link.
  • Use https://registry.platformio.org/libraries/thomasfredericks/MicroSlip for framing packets over the serial port.
esp32-c5
esp32-c3
I got this ESP-C5-devkitC-1 board, and it worked for me:
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
See https://github.com/bertrik/its-g5-receiver
This is heavily inspired by https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware but with a fixed size ring buffer instead of dynamic allocation.
Compiling the firmware
Uses python and platformio, see the README.md in the source archive.
Watch packets come in:
 pio device monitor
Then viewed in wireshark:
 wireshark message.pcap
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
See also https://github.com/pit711/v2x2map/blob/main/firmware/main/mqtt.c
In short: server = mqtts://cits1.opentrafficmap.org:8883 , no user/pass:
  • topic 'its/<node>/status' (online or offline), retained
  • topic 'its/<node>/info' with a JSON string
  • topic 'its/<node>/packet' for sniffed packets (raw, not JSON encoded)
