Its-g5
| Project ITS-G5 | |
| Investigating ITS-G5 signals | |
| Last Update | 2026-06-22 |
Stuff to investigate:
- Source code for an ITS-G5 receiver https://github.com/pit711/v2x2map
- Crowd-sourced live map of messages received: https://opentrafficmap.org/
- Simplest source code for Arduino-based sniffer: https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware
- How to contribute to opentrafficmap: https://wiki.opentrafficmap.org/?utm_source=chatgpt.com#zur_karte_beitragen
I got this board, and it worked for me:
- aliexpress product page https://nl.aliexpress.com/item/1005012416463528.html
- espressif schematic https://dl.espressif.com/dl/schematics/SCH_ESP32-C5-DevkitC-1_V1.1_20240621.pdf
- espressif devkit-c page: https://docs.espressif.com/projects/esp-dev-kits/en/latest/esp32c5/esp32-c5-devkitc-1/user_guide.html
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
Connect your USB-C cable to the "UART" port. It is connected to an actual USB-UART converter chip and always shows up, regardless of whether the ESP32 is in reset or not.
See https://github.com/bertrik/its-g5-receiver
Compiling the firmware
Needs python.
Preparation:
- If you didn't have a python venv, create it:
python -m venv .venv
- Activate the venv:
bash source .venv/bin/activate
- Install platformio into the venv:
python pip install platformio
Compile and upload:
Watch packets come in:
pio device monitor
Then viewed in wireshark:
wireshark message.pcap
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
