Its-g5
| Project ITS-G5 | |
| File:Yunopicture.png | |
| Investigating ITS-G5 signals | |
| Last Update | 2026-06-20 |
Stuff to investigate:
- Source code for an ITS-G5 receiver https://github.com/pit711/v2x2map
- Crowd-sourced live map of messages received: https://opentrafficmap.org/
- Simplest source code for Arduino-based sniffer: https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware
I got this board, and it worked for me: https://nl.aliexpress.com/item/1005012416463528.html
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
TODO
