Treinonderdelen/ICMm/Bestemmingsaanduiding
< Treinonderdelen | ICMm
Het LED-display aan de buitenkant dat aangeeft waar de trein naartoe gaat.
- Fabrikant: Focon Electronic Systems A/S
- Onderdeelnummers:
- Nedtrain:
- YA082984
- YA08298C
- Focon:
- Item no.: 800313-02 ("External Side Display (ESD)")
- Customer item no.: G464389
- Assets: 390024 ("Focon Electronic Systems A/S DSB dot 16")
- Nedtrain:
Grotendeels gebaseerd op dezelfde hardware als het SGMm-display, maar véél beter in elkaar gezet.
- Flash:
Resolutie: 160 x 32
Connectors
Één Harting Han 24DD-connector aan de bovenkant van het display, met de volgende pinout:
_/-----------\_
_/ 21 - 23 - \_
/ 17 - 19 - \
| 13 - - - |
| 9 - - - |
\_ - - - - _/
\_ 1 2 - - _/
1: power Vcc
2: power GND
3: N/C [no pin]
4: N/C [no pin]
5: N/C [no pin]
6: N/C [no pin]
7: N/C [no pin]
8: N/C [no pin]
9: address bit (0?)
10: address bit (1?) [no pin]
11: address bit (2?) [no pin]
12: address bit (3?) [no pin]
13: RS-485 GND
14: RS-485 GND (for address bit 2?) [no pin?]
15: RS-485 GND (for address bit 1?) [no pin?]
16: RS-485 GND (for address bit 0?) [no pin?]
17: RS-485 in-
18: RS-485 in- [no pin]
19: RS-485 out-
20: (debug RX?) [no pin]
21: RS-485 in+
22: RS-485 in+ [no pin]
23: RS-485 out+
24: (debug TX?) [no pin]
Één interne JST-connector van de hoofdconnector naar het logica-bord, niet nodig voor externe verbinding:
Pin 1: RS-485 IN+ [external: pins 21 and 22] Pin 2: RS-485 IN- [external: pins 17 and 18] Pin 3: signal GND [external: pins 13-16] Pin 4: (debug RX?) [external: pin 20] Pin 5: (debug TX?) [external: pin 24] Pin 6: signal GND [external: pins 13-16] Pin 7: address bit (0?) [external: pin 12] Pin 8: address bit (1?) [external: pin 11] Pin 9: address bit (2?) [external: pin 10] Pin 10: address bit (3?) [external: pin 9]
