MysteryLidar
Project MysteryLidar | |
Aliexpress Mystery Lidar | |
Contact | bertrik |
Last Update | 2024-08-03 |
I bought a cheap lidar from AliExpress, no guarantees, no datasheets. This page is about understanding it and reverse engineering the protocol
Protocol
Serial bit rate is 23400 bps
From the Aliexpress page:
Baud: 230400; Packet_length=60Bytes (in every ~4ms period) B0= 0x55 B1=0xAA B2=0x23 B3=0x10 B4+B5=current resolution LSB+MSB B6+B7= Start Angle of this packet LSB+MSB 16x: B8:B9= Distance LSB+MSB B10= Quality (1 byte only) . . . B56+B57= Final Angle of this packet (LSB+MSB) B58+B59= CRC
Some numbers:
- each packet is 60 bytes
- each packet contains 16 measurements
- there are about 35 packets per rotation
- there are about 6 rotations per second
