GridFrequency
| Last Update | 2023-05-31 |
Concept
Desired end result:
Algoritm
Algorithm for getting accurate instantaneous frequency:
- Sample the mains frequency waveform during approximately 100 ms
- Determine the median, lower and upper quartiles of the waveform amplitude data
- During approximately 1000 ms, sample the waveform, applying an amplitude shift according to the median, to make the waveform symmetric around zero
- While sampling, run a state machine to perform a linear regression around the zero-crossing of the wavefrom. The start and end point of this regression are the lower and higher quartile.
- Use the linear regression to calculate the interpolated time of the zero-crossing (the regression gives sub-sample resolution). Keep track of the first and last zero-crossing time.
- Calculate the frequency from the time difference between the interpolated zero-crossings
Ideas
- While playing around with an STM32 blue pill, it turned out you might not need a mains power interface at all. A piece of wire picks up ambient 50 Hz already. Typical accuracy of the STM32 clock crystal appears a bit lower than that of the ESP8266, but for visualisation this might not be so important. We don't need the WiFi-functionality of the ESP8266 if just visualizing. This simplifies things: required hardware is just bluepill + piece-of-wire + RGB LED ring.
- A raspberry pi pico appears to be able to satisfy many requirements:
- Able to sample mains frequency directly from ambient signals on its sensitive A/D input, without the need for a transformer circuit
- Able to sample a signal with good timing accuracy, it has a crystal better than 30 ppm (0.0015 Hz at 50 Hz)
- Might allow control of a LED ring using FastLED for visualisation (not possible with STM32), to be researched
- Has WiFi support, although rather dodgy on the Arduino platform, for publishing directly to mqtt
- Relatively inexpensive
Visualisation
Mains waveform ring
Concepts:
Calculation:
| GND | GND | Ground |
| VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
| OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
To flash the esp8266:
- install platformio
- enter the esp8266sampler directory
cd esp8266sampler
- compile and upload
