GridFrequency
Project MainsFrequency2.0
Last Update 2023-03-16
Concept
Desired end result
  • get more accurate frequency measurement
  • get more responsive frequency measurement, i.e. instantaneous value, not a running average over 50 seconds.
Algorithm for getting accurate instantaneous frequency out of it:
  • Sample the mains frequency waveform during approximately one second (say 5 - 10 kHz)
  • Determine the median, lower and upper quartiles of the waveform, and shift data so its values are symmetrically around zero
  • Calculate zero crossings by doing linear regression to find the zero-crossing of the wave in the region around the zero crossing (in between the quartile values), this gives sub-sample time resolution
  • The linear regression runs a kind of state machine, just keeping track of sum(x), sum(y), sum(x*x), sum(x*y) is enough to perform a linear regression at any time
  • Do this over the approximately 50 cycles contained in the one second data and determine average frequency
Connections
ZMPT101B Wemos D1 mini Remark
GND GND Ground
VCC? 5V Power
pin? A0 Analog mains waveform, 0..5V
