Stofradar
Project Stofradar
Visualizing airborne particulate matter concentrations on a map
Last Update 2022-11-29
Visualisation of citizen-science data by RIVM in the samenmeten project can be found here.
See also my DustSensor page.
Future activities:
  • add a water mark
  • add some kind of slider to indicate progress on the GIF image, or even allow the user to slide back and forth
  • fix the problem of stale data
Stale data
Sensor.community nodes typically provides data at high time resolution, a few minutes, with a 'heartbeat' update of 5 minutes. Some data sources provide relatively stale data, data is only updated once per hour and once the application picks it up the data is already over an hour old. Data sources with such different latencies cannot be combined properly in a single near-realtime image.
This is handled by providing with each image a maximum age of the data. For the Rotterdam visualisation this is a couple of hours (most of the sensor are from the luchtclub project, which has high latency). For the Netherlands visualisation, this is a maximum of one hour, meaning that data from Rotterdam is not visible on the national map.
Visualisation
Background map
Data filtering
Data is raw PM2.5 data taken from:
  • sensor.commnunity (5 minute data)
  • RIVM samenmeten data portal (60 minute data)
  • meetjestad
There is only very minimal data filtering. Sensor measurements are taken into account as follows:
  • Sensors from an area 2x2 times bigger than the area visualized are considered for visualisation
  • Sensors marked as 'indoor' are ignored
  • Sensors with a measurement value smaller than 0 are ignored
  • The top percent of highest PM2.5 concentrations is discarded, this mostly takes care of outliers caused by defective sensors
  • When sensor data is not available in the past 5 minutes, data from a previous measurement interval is used, up to 1 hour old
  • A (small) number of sensors that are known to always report a very high value are not considered (blacklisted)
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
New plan to improve the situation of stations with anomalous data having a large influence:
  • for every pixel, consider only the stations within a certain radius, say 10km for the netherlands map
  • if there are 3 or more stations in range:
    • interpolate with inverse-distance-weighing using the values in range, but disregard the stations with highest and lowest value
    • else (less than 3 stations) don't interpolate, this means transparent color
  • if within some minimum distance from a station, render pixels with flat color according to its measurement value (even when it is an outlier)
Colour range
Luchtmeetnet ranges
Correction for high humidity
The map is currently not corrected for high humidity, however the median of a subset of humidity sensors in the map area is determined and displayed on the image. Only humidity sensors of type BME280 are considered, they are considered to be of better quality than a DHT11 or DHT22 sensor. Not all particulate matter measurement stations have a humidity sensor onboard.
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect becomes really significant above approximately 70% humidity.
Animation
  • GIF animation composed of hourly images over the past 24 hours
  • MP4 animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the MP4 animation.
