Stofradar
Project Stofradar
Visualizing airborne particulate matter concentrations on a map
Last Update 2022-05-19
Visualisation of citizen-science data by RIVM in the samenmeten project can be found here.
See also my DustSensor page.
Future activities:
  • add a water mark
  • add some kind of slider to indicate progress on the GIF image, or even allow the user to slide back and forth
  • fix the problem of stale data
Stale data
Perhaps the next things to tackle is how to handle stale data.
Some data sources are not as frequent (5 min) as the sensor.community data. For example, some data from samenmeten undergoes several stages of aggregation, is only updated hourly and is often over three hours old already.
Perhaps invent some kind of weighing factor so that stale/old data is still used, but does not deteriorate the overall quality when combined with other data:
  • there is already a mechanism in place to weigh local PM concentrations by distance to measurement points
  • perhaps also add a mechanism to account for weighing by age of the measurement?
  • for example simply use age as a weighing factor: a 5-minute old measurement from sensor.community is regarded as 24 times more important than a 2-hour old samenmeten measurement
Visualisation
Background map
Data filtering
Data is raw PM2.5 data taken from:
  • sensor.commnunity (5 minute data)
  • RIVM samenmeten data portal (60 minute data)
There is only very minimal data filtering. Sensor measurements are taken into account as follows:
  • Sensors from an area 2x2 times bigger than the area visualized are considered for visualisation
  • Sensors marked as 'indoor' are ignored
  • Sensors with a measurement value smaller than 0 are ignored
  • The top percent of highest PM2.5 concentrations is discarded, this mostly takes care of outliers caused by defective sensors
  • When sensor data is not available in the past 5 minutes, data from a previous measurement interval is used, up to 1 hour old
  • A (small) number of sensors that are known to always report a very high value are not considered (blacklisted)
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
Colour range
Luchtmeetnet ranges
Correction for high humidity
The map is currently not corrected for high humidity, however the median of a subset of humidity sensors in the map area is determined and displayed on the image. Only humidity sensors of type BME280 are considered, they are considered to be of better quality than a DHT11 or DHT22 sensor. Not all particulate matter measurement stations have a humidity sensor onboard.
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect becomes really significant above approximately 70% humidity.
Animation
  • GIF animation composed of hourly images over the past 24 hours
  • MP4 animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the MP4 animation.
