Stofradar
| Project Stofradar | |
| Visualizing airborne particulate matter concentrations on a map | |
| Last Update | 2021-10-15 |
See also my DustSensor page.
Future activities:
- play with different algorithm:
- for each pixel consider only stations with a certain radius (say 10 km), calculate the median, convert median to color
- should more naturally filter out outliers and is actually a bit similar to what sensor.community uses.
- plot official luchtmeetnet measurements on the map too, access to the API has been implemented work in progress
base humidity on BME280 sensors only, ignore DHT11/22 type sensors- add a water mark
Visualisation
Background map
Data filtering
There is only very minimal data filtering. Sensor measurements are taken into account as follows:
- Sensors from an area 2x2 times bigger than the area visualized are considered for visualisation
- Sensors marked as 'indoor' are ignored
- Sensors with a measurement value smaller than 0 are ignored
- The top percent of highest PM2.5 concentrations is discarded, this mostly takes care of outliers caused by defective sensors
- When sensor data is not available in the past 5 minutes, data from a previous measurement interval is used, up to 1 hour old
- A (small) number of sensors that are known to always report a very high value are not considered (blacklisted)
Interpolation
- calculate the "middle" of the map (average latitude/longitude between top-left and bottom-right);
- calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
- calculate the "km-per-degree-longitude" at the middle for longitude as the number above multiplied with cos(latitude);
- determine the difference in longitude and the difference in latitude;
- convert both to km using the factors calculated earlier;
- calculate the euclidean distance.
PM10 values < 0 ug/m3 are ignored in the software.
Colour range
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
- https://www.samenmetenaanluchtkwaliteit.nl/sites/default/files/2018-07/Status_SDS011_12juli18.pdf
- https://www.researchgate.net/publication/320474792_Influence_of_Humidity_on_the_Accuracy_of_Low-Cost_Particulate_Matter_Sensors
- https://github.com/opendata-stuttgart/meta/wiki/Luftfeuchte-Korrektur
- it combines formulas and coefficients from different sources where relative humidity has different units. One paper seems to use an RH-value from 0 to 100, while another uses a kind of normalized relative humidity (from 0 to 1). You cannot just use the same coefficients if the unit is different.
- it claims a humidity correction for PM10 with coefficients that is not found in the source paper.
Animation
- GIF animation composed of hourly images over the past 24 hours
- WEBM animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the WEBM animation.
