Stofradar
Project Stofradar | |
Visualizing atmospheric particulate matter concentrations on a map | |
Status | Completed |
Contact | bertrik |
Last Update | 2021-09-15 |
See also my DustSensor page.
Future activities:
- find a universally agreed-upon color scale, and add a legend
- investigate why sometimes an image cannot be calculated (API not accessible?)
plot official luchtmeetnet measurements on the map too, access to the API has been implementedwork in progress
Visualisation
Background map
Data filtering
There is only very minimal data filtering. Sensor measurements are taken into account as follows:
- Sensors from an area 2x2 times bigger than the area visualized are considered for visualisation
- Sensors marked as 'indoor' are ignored
- Sensors with a measurement value smaller than 0 are ignored
- The top percent of highest PM2.5 concentrations is discarded, this mostly takes care of outliers caused by defective sensors
- When sensor data is not available in the past 5 minutes, data from a previous measurement interval is used, up to 1 hour old
- A (small) number of sensors that are known to always report a very high value are not considered (blacklisted)
Interpolation
- calculate the "middle" of the map (average latitude/longitude between top-left and bottom-right);
- calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
- calculate the "km-per-degree-longitude" at the middle for longitude as the number above multiplied with cos(latitude);
- determine the difference in longitude and the difference in latitude;
- convert both to km using the factors calculated earlier;
- calculate the euclidean distance.
PM10 values < 0 ug/m3 are ignored in the software.
Colour range
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
- https://www.samenmetenaanluchtkwaliteit.nl/sites/default/files/2018-07/Status_SDS011_12juli18.pdf
- https://www.researchgate.net/publication/320474792_Influence_of_Humidity_on_the_Accuracy_of_Low-Cost_Particulate_Matter_Sensors
- https://github.com/opendata-stuttgart/meta/wiki/Luftfeuchte-Korrektur
- it combines formulas and coefficients from different sources where relative humidity has different units. One paper seems to use an RH-value from 0 to 100, while another uses a kind of normalized relative humidity (from 0 to 1). You cannot just use the same coefficients if the unit is different.
- it claims a humidity correction for PM10 with coefficients that is not found in the source paper.
Animation
- GIF animation composed of hourly images over the past 24 hours
- WEBM animation composed of 5-minute images over the past 24 hours
You can click on the GIF animation to view the WEBM animation.
