Stofradar
Project Stofradar
Visualizing atmospheric particulate matter concentrations on a map
Last Update 2021-09-03
See also my DustSensor page.
The website sensor.community is an initiative to allow citizens to participate in measuring atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is > 10000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has > 1000 sensors. See also [1].
Future activities:
  • find a universally agreed-upon color scale, and add a legend
  • investigate why sometimes an image cannot be calculated (API not accessible?)
  • plot official luchtmeetnet measurements on the map too, access to the API has been implementedwork in progress
Visualisation
Background map
What I need/want is to be able to specify the 'bounding box' and use a equirectangular projection , so I can easily map a pixel back to a latitude/longitude.
The equirectangular projection is contained in standard EPSG-32662
Interpolation
  • calculate the "km-per-degree-latitude" at the middle for latitude as 40075 km / 360 degrees;
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
Pixels that are not within a certain distance of any sensor station (e.g. 25 km) are rendered as grayscale, to indicate a geographic limit of each sensor.
PM10 values that are < 0 or > 500 ug/m3 are simply ignored in the software.
Colour range
right
The colours I'm using (a kind of inverted spectral range from blue to red):
  • 0 ug/m3: fully transparent white (#FFFFFF)
  • 25 ug/m3: semi-transparent cyan (#00FFFF)
  • 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average for PM10 in the Netherlands.
  • 100 ug/m3: semi-transparent red (#FF0000)
  • 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Scale used for Luchtmeetnet luchtkwaliteitsindex from RIVM:
https://www.luchtmeetnet.nl/informatie/luchtkwaliteit/luchtkwaliteitsindex-(lki)
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
Compositing
I use imagemagick for this, for example:
 composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
Animation
The idea of animation is to combine several 5-minute images into a movie.
There are several options and file formats to choose from:
  • GIF appears way too big, resulting in files of about 40 MB for 288 frames.
  • APNG is only slighty smaller at about 37 MB.
  • the webm format seems more suited, can be less than 1MB (lossy, VP9).
Example conversion command for webm:
 cat ~/luftdatenmapper/tmp/netherlands/*.png |ffmpeg -f image2pipe -r 12 -i - -b:v 200k netherlands.webm
This results in an output file of about 650 kB.
