StofAnanas
Project StofAnanas
Last Update 2022-04-03
The concept
The stofananas/stoflama visualizes the current airborne particulate matter concentration from the nearest sensor.community measurement station, inspired by http://stoflamp.nl The data that the LED colour is based on is retrieved over WiFi from the sensor.community website every 5 minutes.
Features:
  • The lamp shows particulate matter concentration as a colour, from dark blue for low concentration to bright pink for high concentration
  • The lamp retrieves the PM value over wifi from the the sensor.community website, there is a one-time setup to configure your WiFi network so the device can access the internet
  • The lamp automatically determines the nearest sensor.community particulate measurement station, by doing WiFi-based geolocation.
  • The number/id of the sensor.community station can also be entered manually during the one-time setup.
Ideas/nice to have/todo:
  • Base colour upon PM2.5 (not PM10) and update colour ranges, e.g. 0 = blue, 10 = green, 20 = yellow, 40 = red, 80 = purple
  • Built-in web server, with links to historic measurement data of the sensor it's monitoring, link to google maps, etc.
    • complication: the nice graphs on madavi.de are based on the *hardware id* (not database id), we can't get that automatically
    • just show a table with all properties in the left column (PM values, WGS84 location) and their values in the right column?
Simplified API
Problems with the current implementation:
  • communicaton with sensor.community fails randomly, or takes very long
  • the auto-detection method puts a burden on the sensor.community servers
  • data from other providers than sensor.community is not returned
New plan:
  • create my own API to get the most recent measurement value for the closest PM sensor
  • the API runs on my own server (www.stofradar.nl), I have full control, not depending on other servers
  • REST-like protocol, e.g. HTTP GET /pm/v1/<latitude>/<longitude> returns a JSON structure
  • response contains list of results, ordered by distance, each with:
    • sensor id
    • PM values
    • time stamp
    • location (lat lon)
  • query parameters
    • maxResults = maximum number of results, e.g. 1 for the closest
    • maxAge = maximum age of measurement (seconds), e.g. 300 for the latest 5-min result
    • maxDistance = maximum distance (meters), e.g. 10000
Building it
stoflama
It consists of a few parts:
  • a Wemos D1 mini board
  • a LED shield, either the one with 1 LED, or the one with 7 LEDs (preferred, brighter)
  • a plastic lamp enclosure
Steps:
  • solder the female headers onto the Wemos D1 mini, start with soldering just one pin so you can re-heat it and adjust it if the fit with the male pins is not quite right.
  • connect the USB micro cable and flash the firmware into the Wemos d1 mini board
  • verify that it works as expected, on startup it does a quick colour animation, starting and ending with the red colour
Operation Manual
stoflama
Flashing the firmware
  • Connect everything up as indicated under 'hardware' and connect the Wemos D1 board to the USB port of your development PC / laptop
  • Flash the software into the Wemos D1 mini. Open a command line and enter the 'stofananas' source code directory, then compile and upload it using the following command:
 sudo apt install python-pip
 sudo pip install platformio
Configuration
configuration
Automatic configuration:
  • power up the lamp
  • when presented with the captive portal, select a WiFi network, fill in the WiFi password, leave the luftdaten id field EMPTY, press SAVE
  • the closest sensor.community particulate matter sensor will automatically be determined
Manual configuration:
  • power up the lamp
Alternatively:
  • make sure at least the WiFi credentials have been entered and saved
  • open a console to the serial port of the wemos D1 mini (115200 bps) and enter the following command:
 config auto
  • within a few seconds, you should see it prints the current approximate geographic location and the id of the sensor.community station, the id should be non-zero. It is saved in internal memory.
Usage
  • A flashing colour (1x per second) means that something went wrong, either communication with the sensor.community server or decoding the sensor.community server response
  • ArduinoJSON (v 6.17.2) for parsing the sensor.community response
  • FastLED (v 3.3.3) is used to control the RGB LED
  • WiFiManager (v 0.15.0) is used to manage WiFi connection to the local WiFi access point
Sensor.community interface
 http://data.sensor.community/airrohr/v1/sensor/<sensor-id>/
where <sensor-id> is the database id used by sensor.community (and visible on their map). The trailing slash in the URL is significant.
For example:
 http://data.sensor.community/airrohr/v1/sensor/12246/
Colour mapping
FastLED rainbow hue chart
Mapping is currently as follows:
  • 0 ug/m3: deep blue
  • 15 ug/m3: green
  • 30 ug/m3: yellow
  • 60 ug/m3: red
  • 120+ ug/m3: pink
Chapter 8.3 unfortunately still puts the final colour scale for an air quality index as a point under discussion:
 "Er is overeenstemming over het baseren van de index op dosis-respons
 relaties en het schalen van de componenten naar ordegrootte
 gezondheidseffecten. De analyse die heeft geleid tot een indeling in tien
 klassen is beschreven in hoofdstuk 6. Er is tevens de wens geuit, zowel
 door gebruikers als experts, om in de uiteindelijke presentatie te komen
 tot vier klassen met bijbehorende kleur, labels en handelingsperspectief.
 De precieze afkappunten daarvoor zijn arbitrair. Na de expertbijeenkomst,
 bijeenkomsten met gebruikers en twee commentaarronden onder de experts
 is nog geen consensus over de uiteindelijke indeling van de index in vier klassen.
 De onderstaande indeling (zie Tabel 11) doet zoveel mogelijk recht aan de adviezen van
 de experts en gebruikers, en biedt mogelijkheden om een consistent
 geheel te vormen met de smogregeling. Nog openstaande
 discussiepunten worden hier beschreven."
The https://www.luchtmeetnet.nl/ site appears to use the following ranges (PM10):
  • 0 - 30: light blue (good)
  • 30 - 75: light yellow (moderate)
  • 75 -  ?: orange (inadequate)
  • ? - ?: red (bad)
  • ? - ?: purple (very bad)
For PM2.5 they appear to use the following ranges:
  • 0 - 20: light blue (good)
  • 20 - 50: light yellow (moderate)
  • 50 -  ?: orange (inadequate)
  • ? -  ? : red (bad)
  • ? -  ? : purple (very bad)
Next generation
lamp-sensor pairing sequence diagram
The next generation uses the ESP-NOW protocol, supported by both the ESP8266 and ESP32 microcontrollers. ESP-NOW is a connection-less WiFi protocol running at a reduced rate of 1 Mbps, it does not require any credentials (like WEP/WPA) to be entered. The lamp is *not* connected to regular WiFi, this is different from (say) the mechanism used by the sensor.community flashing tool to find a sensor in the local network.
The idea is that you just put a ESP-now enabled light in the vicinity (several 10s of meters) of the particulate matter sensor and they will automatically discover each others' presence and start communicating measurement values.
Protocol
Pairing works as follows:
  • The lamp sends broadcast discovery messages (possibly on different channels) to announce its presence and discover the sensor, it flashes blue while doing so.
  • The dust sensor receives the broadcast discovery message and sends an associate message back.
  • The lamp receives the associate message, it stops flashing blue.
  • The (implicit) ACK from the lamp back to the sensor signals that the association is complete, the sensor remembers the lamp MAC and id
  • When a new measurement is done, the sensor sends a data message to the lamp. The lamp shows the associated color.
 {"msg":"data","PM10":12.3,"PM2.5":8.4,"PM1.0":4.5,"humidity":42.5,"temperature":14.3,"pressure":102511,"color":"#11FF00"}
 {"msg":"data","color":"#ffff00"}
The lamp software can be implemented to either just display the color, or calculate it from the measurement.
Source code is available here: https://github.com/bertrik/pmlamp-espnow-proto
Power on the lamp, the LED starts flashing blue, then power on the sensor, the LED stops flashing. You can connect over serial to the sensor node and type a command like 'led FF0000' to set the color of the lamp to red.
Other resources
