Sensor-data-bridge
| Project LoraLuftdatenForwarder | |
| Bestand:Nopicture.jpg | |
| LoRaWAN forwarder for particulate matter data | |
| Last Update | 2021-03-07 |
What is this
This is a Java application that sends airborne particulate matter measurement data from TheThingsNetwork and forwards it to sensor.community (formerly Luftdaten).
It is used in combination with my LoraWanDustSensor: the sensor sends measurement data to TheThingsNetwork, this application picks up the data from TheThingsNetwork and forwards it to sensor.community and to opensensemap.org.
Requirements
You need the following:
- a Java installation (JDK to compile), at least version 8
Compilation
To compile the software:
- enter the LoraLuftdatenForwarder/gradle directory
- run the gradle script to build the software:
./gradlew assemble
- the application zip is now available in LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions
git pull
Installation
cd tar xvf code/LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions/LoraLuftdatenForwarder.tar
Configuration
Device side
TheThingsNetwork
- Within the application, ou need a 'device', create a new one, or use an existing one:
- OTAA
- Use the application keys as specified in my [[1]] page
- You need an API key
- Create this on the TTN console, for now just create a key that grants all rights
This application
To configure the application:
cd LoraLuftdatenForwarder bin/LoraLuftdatenForwarder (ctrl-C)
- Edit the loraluftdatenforwarder.yaml file, example:
ttn:
mqtt_url_v2: "tcp://eu.thethings.network"
mqtt_url_v3: "tcp://eu1.cloud.thethings.network"
identity_server_timeout: 20
apps:
- name: "particulatematter"
version: "V3"
key: "NNSXS......."
encoding: "CAYENNE"
luftdaten:
timeout: 20
opensense:
timeout: 20
ids:
"0ttn-deveui-here": "put-opensense-boxid-here"
"0004A30B001E00BE": "5eca4a0fd0545b001c0e5d46"
Sensor.community
TODO
- Register a node with id 'TTN-<device-EUI-as-shown-on-display>'
Opensensemap
TODO
- Create a node with the proper configuration
- Copy the opensensenmap 'box id'
- Add an attribute in the TTN console:
- Go to the TTN console, General settings of the device
- Add attribute, name = 'opensense-id', value = box id that you just copied
- The boxid should be picked up automatically by the forwarder, within an hour
