StofAnanas
| Project StofAnanas | |
| Showing particulate matter concentration as a coloured light | |
| Last Update | 2020-12-31 |
The concept
The stofananas/stoflama visualizes the current airborne particulate matter concentration from the nearest sensor.community measurement station, inspired by http://stoflamp.nl The data that the LED colour is based on is retrieved over WiFi from the sensor.community website every 5 minutes.
Features:
- The lamp shows PM10 particulate matter concentration as a colour, from dark blue for low concentration to bright pink for high concentration
- The lamp retrieves the PM value over wifi from the the sensor.community website, there is a one-time setup to configure your WiFi network so the device can access the internet
- The lamp automatically determines the nearest sensor.community particulate measurement station, by doing WiFi-based geolocation.
- The number/id of the sensor.community station can also be entered manually during the one-time setup.
- The hardware consists of a Wemos D1 mini board (about E3,-), a LED shield and a USB power supply + cable.
- The software supports two different kinds of Wemos D1 mini LED "shield", both the shield with a single LED and the shield with 7 LEDs arranged in a star.
Ideas/nice to have:
- Built-in web server, with links to historic measurement data of the sensor it's monitoring, link to google maps, etc.
- complication: the nice graphs on madavi.de are based on the *hardware id* (not database id), we can't get that automatically
- just show a table with all properties in the left column (PM values, WGS84 location) and their values in the right column?
- some kind of compatibility mode with the stoflamp from stoflamp.nl
- Run the software directly on a WiFi-enabled E14 RGB lamp from the Action store. This lamp has the microcontroller already built in. No separate USB power adapter is needed, it runs directly off 230V. See the WifiLamp project.
Building it
It consists of a few parts:
- a Wemos D1 mini board
- a LED shield, either the one with 1 LED, or the one with 7 LEDs (preferred, brighter)
- a 5V USB charger with stable voltage output + USB cable
- a plastic lamp enclosure
Steps:
- solder the female headers onto the Wemos D1 mini, start with soldering just one pin so you can re-heat it and adjust it if the fit with the male pins is not quite right.
- push the male headers into the female headers and solder the male headers onto the LED shield
- connect the USB micro cable and flash the firmware into the Wemos d1 mini board
- verify that it works as expected, on startup it does a quick colour animation, starting and ending with the red colour
- remove the USB micro cable and push the Wemos d1 mini board + LED shield into the plastic enclosure
- reattach the USB micro cable and verify it still works
Operation Manual
Flashing the firmware
- Connect everything up as indicated under 'hardware' and connect the Wemos D1 board to the USB port of your development PC / laptop
- Flash the software into the Wemos D1 mini. Open a command line and enter the 'stofananas' source code directory, then compile and upload it using the following command:
sudo apt install python-pip sudo pip install platformio
Configuration
Automatic configuration:
- power up the lamp
- on a mobile phone, connect to the "ESP-PMLAMP" network, and select login
- when presented with the captive portal, select a WiFi network, fill in the WiFi password, leave the luftdaten id field EMPTY, press SAVE
- the closest sensor.community particulate matter sensor will automatically be determined
Manual configuration:
- on https://netherlands.maps.luftdaten.info find the particulate matter station you want to follow and note the number of the station, for example "12246"
- power up the lamp
- when presented with the captive portal, select a WiFi network, fill in the WiFi password, AND ALSO fill in the number you looked up earlier, press SAVE
Alternatively:
- make sure at least the WiFi credentials have been entered and saved
- open a console to the serial port of the wemos D1 mini (115200 bps) and enter the following command:
config auto
- within a few seconds, you should see it prints the current approximate geographic location and the id of the sensor.community station, the id should be non-zero. It is saved in internal memory.
Usage
- Power up the lamp while in range of the WiFi network you configured. The LED shows a colour animation when starting up (starting with red and ending with red)
- The LED turns white for a short time, then changes to a colour representing a PM concentration
- A new PM measurement is retrieved automatically every 5 minutes.
- A flashing colour (1x per second) means that something went wrong, either communication with the sensor.community server or decoding the sensor.community server response
- 1-LED shield: https://wiki.wemos.cc/products:d1_mini_shields:ws2812b_rgb_shield
- 7-LED shield: https://wiki.wemos.cc/products:d1_mini_shields:rgb_led_shield
- ArduinoJSON (v 6.17.2) for parsing the sensor.community response
- FastLED (v 3.3.3) is used to control the RGB LED
- WiFiManager (v 0.15.0) is used to manage WiFi connection to the local WiFi access point
Sensor.community interface
http://api.luftdaten.info/v1/sensor/<sensor-id>/ http://data.sensor.community/airrohr/v1/sensor/<sensor-id>/
where <sensor-id> is the database id used by sensor.community (and visible on their map). The trailing slash in the URL is significant.
For example:
http://api.luftdaten.info/v1/sensor/12246/ http://data.sensor.community/airrohr/v1/sensor/12246/
Colour mapping
- 0 ug/m3: deep blue
- 15 ug/m3: green
- 30 ug/m3: yellow
- 60 ug/m3: red
- 120+ ug/m3: pink
Next generation
The next generation will work as follows:
- The protocol is ESP-NOW between roles 'lamp' and 'sensor', both can be ESP8266. ESP-NOW is a connection-less WiFi protocol running at a reduced rate of 1 Mbps, it does not require any credentials (like WEP/WPA) to be entered. The lamp is *not* connected to regular WiFi, this is different from (say) the mechanism used by the sensor.community flashing tool to find a sensor in the local network.
- On startup, the lamp sends broadcast discovery messages at a regular interval, say every second, it flashes blue while doing so.
- The sensor receives the discovery message and completes a pairing / association sequence with the lamp.
- When a new measurement is done, the lamp sends a data message to the lamp. The lamp shows the associated color.
Pairing works as follows:
- The lamp sends broadcast discovery messages (possibly on different channels) to announce its presence and discover the sensor, it flashes blue while doing so.
- The dust sensor receives the broadcast discovery message and sends an associate message back.
- The lamp receives the associate message, it stops flashing blue.
- The (implicit) ACK from the lamp back to the sensor signals that the association is complete, the sensor remembers the lamp MAC and id
{"msg":"data","PM10":12.3,"PM2.5":8.4,"PM1.0":4.5,"humidity":42.5,"temperature":14.3,"pressure":102511,"color":"#11FF00"}
{"msg":"data","color":"#ffff00"}
The lamp software can be implemented to either just display the color, or calculate it from the measurement.
Source code is available here: https://github.com/bertrik/pmlamp-espnow-proto
Power on the lamp, the LED starts flashing blue, then power on the sensor, the LED stops flashing. You can connect over serial to the sensor node and type a command like 'led FF0000' to set the color of the lamp to red.
