LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2020-08-08
The concept
The concept consists of:
  • a forwarder application that collects the data from TTN and forwards it to luftdaten.info, opensensemap, mycayenne dashboard, etc.
  • the node shows its unique Device EUI on the OLED
  • at the TTN console, you register the node with the unique Device EUI
  • done!
  • update TTN upload schedule, to add some randomness and avoid collisions
  • disable screen when idle, to avoid burn-in of the OLED?
  • support for other meteo sensors?
  • internal web server, for configuration, information?
The node is based on Arduino, in particular a TTGO ESP32 board ("ttgo-lora32-v1") with onboard SX1276 LoRa chip. The sensor is an SDS-011, just like in the luftdaten project. For humidity/temperature, I am using a BME280 (superior to the DHT11/22).
TODO: plaatjes van de hardware
Pinout
TTGO LoRa v1 Heltec LoRa v2 Sensor Remark
5V 5V SDS011 5V (pin 3) triple-check this, swapping 5V/GND destroys the SDS011
GND GND SDS011 GND (pin 5) triple-check this, swapping 5V/GND destroys the SDS011
GPIO25 - SDS011 RXD (pin 6) to be moved to GPIO23
GPIO35 - SDS011 TXD (pin 7) to be moved to GPIO22
3.3V 3.3V/Vext BME280 3V Both Vext and 3.3V can be used
GPIO4 GPIO4 BME280 SDA data
GPIO15 GPIO15 BME280 SCL data
GND GND BME280 GND ground
For reference:
TTGO LoRa v1
Technical documents:
Heltec LoRa v2
Source code
Payload encoding
Cayenne
  • PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3 (optional)
  • PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • Humidity: humidity (type 104), with value in units of 0.5 %
  • Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about 86400x0.01x2 = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day, actually a huge restriction compared to the send time allowed purely by radio regulations.
  • The Luftdaten backend appears to run on a 5 minute interval, or 288 measurements per day.
  • The default Luftdaten firmware sends new data every 145s by default
  • skip T/RH/P completely (8 bytes left): SF7 is possible, at SF8 we spend 102 ms per transmission
  • skip P only (15 bytes left): SF7 is possible, at SF8 we spend 123 ms per transmission
Node design
  • INIT: determine presence of the SDS011, print the SDS011 serial number
  • IDLE: wait until the start of the cycle, then turn on the fan
  • WARMUP: wait 20 seconds while the sensor "warms up"
  • MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
To compile and upload:
TTN key provisioning
  • Each node can be programmed with the *same* software, no source code modification is required
  • The node administrator needs to enter the following properties at the TTN console, for each node:
    • The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
    • The App EUI has a fixed value and is the same for all nodes
    • The App Key has a fixed value and is the same for all nodes
    • Use 32-bit frame counter, disable frame counter checks
  • The node does over-the-air-activation (OTAA) only once and then stores the OTAA parameters in internal (simulated) EEPROM. Upon reboot, the node resumes the connection with these parameters
Backend
  • subscribe to a TTN MQTT stream and receive incoming messages
  • decode Cayenne and custom payloads
  • forward to luftdaten.info/sensor.community
  • forward to opensensemap.org
  • forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Example upstream data:
Example downstream data:
Gateway API:
