LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2020-06-21
The concept
The concept consists of:
  • a forwarder application that collects the data from TTN and forwards it to luftdaten.info, opensensemap, mycayenne dashboard, etc.
  • the node shows its unique Device EUI on the OLED
  • at the TTN console, you register the node with the unique Device EUI
  • done!
  • select a more sensible set of pins for the SDS011 and the BME280
  • test BME280
The node is based on Arduino, in particular a TTGO ESP32 board with onboard SX1276 LoRa chip. The sensor is an SDS-011, just like in the luftdaten project. For humidity/temperature, I am using a BME280 (superior to the DHT11/22).
NOTE: https://www.thethingsnetwork.org/community/berlin/post/warning-attention-users-of-ttgo21-v16-boards-labeled-t3_v16-on-pcb-battery-exploded-and-got-on-fire
Hardware connections:
  • SDS011 5V to ESP32 5V
  • SDS011 GND to ESP32 GND
  • SDS011 TXD to ESP32 GPIO35
  • SDS011 RXD to ESP32 GPIO25
  • BME280 3V to ESP32 3.3V
  • BME280 SDA to ESP32 GPIO4
  • BME280 SCL to ESP32 GPIO15
  • BME280 GND to ESP32 GND
Not just any pin on the ESP32 can be used an GPIO, some are input only, see https://randomnerdtutorials.com/esp32-pinout-reference-gpios/
Source code
Payload encoding
Cayenne
  • PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3 (optional)
  • PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • Humidity: humidity (type 104), with value in units of 0.5 %
  • Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about 86400x0.01x2 = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day, actually a huge restriction compared to the send time allowed purely by radio regulations.
  • The Luftdaten backend appears to run on a 5 minute interval, or 288 measurements per day.
  • The default Luftdaten firmware sends new data every 145s by default
  • skip T/RH/P completely (8 bytes left): SF7 is possible, at SF8 we spend 102 ms per transmission
  • skip P only (15 bytes left): SF7 is possible, at SF8 we spend 123 ms per transmission
Node design
  • INIT: determine presence of the SDS011, print the SDS011 serial number
  • IDLE: wait until the start of the cycle, then turn on the fan
  • WARMUP: wait 20 seconds while the sensor "warms up"
  • MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
To compile and upload:
TTN key provisioning
  • Each node can be programmed with the *same* software, no source code modification is required
  • The node administrator needs to enter the following properties at the TTN console, for each node:
    • The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
    • The App EUI has a fixed value and is the same for all nodes
    • The App Key has a fixed value and is the same for all nodes
    • Use 32-bit frame counter, disable frame counter checks
  • The node does over-the-air-activation (OTAA) only once and then stores the OTAA parameters in internal (simulated) EEPROM. Upon reboot, the node resumes the connection with these parameters
Backend
  • subscribe to a TTN MQTT stream and receive incoming message
  • decode Cayenne and custom payloads
  • forward to luftdaten.info/sensor.community
  • forward to opensensemap.org
  • forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Example upstream data:
Example downstream data:
Gateway API:
