LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2020-05-26
The idea
  • a forwarder application that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but it appears there is no universal solution. I am publishing all source code on github and will put up documentation on this wiki. Everyone appears to invent their own payload format, I'd like something more universal like Cayenne. This page proposes an encoding based on the Cayenne standard.
One thing in particular I'd like to do better than existing solutions is to use proper OTAA for the LoRa connection to TTN. OTAA means over-the-air-activation and is a mechanism to dynamically negotiate communication/encryption keys instead of programmed specifically in each sensor node. Once the OTAA is done successfully, the node remembers the network id, device address, session keys, etc for future communication.
  • the node shows its unique id on the OLED
  • at the TTN console, you register a new device with the unique id
  • done!
  • Are we bound by a 5 minute interval towards Luftdaten (dropping off the maps if sending less frequently)? YES PROBABLY
  • Implement a kind of schedule: turn the sds011 on, wait some time, take a measurement, turn it off, wait for some time
    • Luftdaten uses default send schedule of 145 seconds
    • make this match the TTN send schedule? -> YES, every 5 minutes, this is achievable even within the TTN FUP at SF7.
    • use the built-in on-off schedule of the sds011? -> NO, we probably want more control over the on-off times
    • implement calculating the median of accumulated measurements (half of the measurements is higher, other half is lower)
The node is based on Arduino, in particular a TTGO ESP32 board with onboard SX1276 LoRa chip. The sensor is an SDS-011, just like in the luftdaten project. For humidity/temperature, I am using a BME280 (superior to the DHT11/22).
NOTE: https://www.thethingsnetwork.org/community/berlin/post/warning-attention-users-of-ttgo21-v16-boards-labeled-t3_v16-on-pcb-battery-exploded-and-got-on-fire
  • SDS011 5V to ESP32 5V
  • SDS011 GND to ESP32 GND
  • SDS011 TXD to ESP32 GPIO35 (maybe I can find two suitable pins close together)
  • SDS011 RXD to ESP32 GPIO25 (maybe I can find two suitable pins close together)
  • BME280 3V todo
  • BME280 SDA todo
  • BME280 SCL todo
  • BME280 GND todo
Source code
Common
Cayenne
HOWEVER:
  • A standard analog value has a resolution of 0.01 units and is signed, leaving a maximum of 327.67 ug/m3. This value is possibly exceeded in extreme cases (new year's eve).
  • Still not as compact as direct binary encoding
So proposed format:
  • PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3 (optional)
  • PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • Humidity: humidity (type 104), with value in units of 0.5 %
  • Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Values encoded are averaged using the median over the accumulated measurements over the measurement interval.
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about 86400x0.01x2 = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day, actually a huge restriction compared to the send time allowed purely by radio regulations.
  • The Luftdaten backend appears to run on a 5 minute interval, or 288 measurements per day.
  • The default Luftdaten firmware sends new data every 145s by default
Using the LoRaWAN airtime calculator we can determine which modes can be used. So with 288 measurements, we can spend 30s / 288 = 104 ms per packet. At 15 bytes payload, this is only possible at SF7, the highest LoRa speed. Stretching the TTN guideline a bit, say by a factor 2, we can achieve those transfers still only at SF7 and SF8. So you need to be relatively close to a gateway.
  • skip T/RH/P completely (8 bytes left): SF7 is possible, at SF8 we spend 102 ms per transmission
  • skip P only (15 bytes left): SF7 is possible, at SF8 we spend 123 ms per transmission
Node
Typical measurement scheme in the Luftdaten firmware, as far as I understand:
  • first it waits until (cycle_time - warmup_time - measure_time), typically 145 s, 15 s and 5 s respectively.
  • turn on the fan and wait 15 seconds for "warmup"
  • measure during 5 seconds
  • turn off the fan
The luftdaten backend appears to have a 5 minute "heartbeat", so we should at least send one measurement to avoid dropping off the map.
Proposed scheme for LoRa sensor:
  • turn fan on and wait 15 seconds, indicate this on the screen
  • measure for 5 seconds, indicate this on the screen
  • turn fan off, show measurement on screen
  • send measurement by LoRa
  • do nothing until the rest of the 5 minute cycle
Platformio
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
To compile and upload:
Design
  • The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
  • The App EUI is generated in the TTN console, it is the same for all nodes
  • The App Key is generated in the TTN console, it is the same for all nodes
  • The device is registered in the TTN console by the Device EUI (this doesn't happen automatically). Frame counter checks are disabled.
  • OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
  • OTAA progress is shown on the OLED
  • If OTAA has been done successfully, the node restores the session parameters negotiated during OTAA on next bootup, so it can quickly resume sending data.
  • I'm NOT saving the upload frame counter (this would be preferable), just disable the feature in the TTN console.
TODO to figure out:
  • What about the channel setup? The node connects using 3 frequencies, but receives a bigger list of frequencies during OTAA JOIN.
 40829907: engineUpdate, opmode=0x8
 40829935: EV_TXSTART
 40829939: engineUpdate, opmode=0x888
 40830013: TXMODE, freq=868300000, len=25, SF=11, BW=125, CR=4/5, IH=0
 40944876: setupRx1 txrxFlags 0x22 --> 01
 start single rx: now-rxtime: 5
 40945013: RXMODE_SINGLE, freq=868300000, SF=11, BW=125, CR=4/5, IH=0
 rxtimeout: entry: 40951170 rxtime: 40945001 entry-rxtime: 6169 now-entry: 5 rxtime-txend: 63524
 41005584: setupRx2 txrxFlags 0x1 --> 02
 start single rx: now-rxtime: 4
 41005720: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
 41017003: process options (olen=0x5)
 41017012: LinkAdrReq: p1:11 chmap:00ff chpage:00 uprt:01 ans:86
 41017019: ??ack error ack=1 txCnt=0
 41017073: decodeFrame txrxFlags 0x2 --> 22
 41017312: Received downlink, window=RX2, port=-1, ack=1, txrxFlags=0x22
 41017708: EV_TXCOMPLETE (includes waiting for RX windows)
 41018027: engineUpdate, opmode=0x800
Backend
This is implemented by my LoraLuftdatenForwarder. It subscribes to the MQTT stream, decodes the telemetry packets and forwards them to the luftdaten API. There is no storage of measurement data in the Java application.
Example upstream data:
Example downstream data:
Gateway API:
