Rondreizendemeukdoos
Project Rondreizende meukdoos | |
Leuke meuk voor een rondreizende ruilactiviteit | |
Contact | Sebastius |
Last Update | 2020-05-25 |
Idea
A box, filled with useful stuff you'd normally lend to friends in need. A care package for us hackers in need!
We use a 'brievenbuspakje', a parcel that can be shipped without visiting a store, just a local mailbox. It will arrive in your mailbox without having to open the door! Cheaper too! It will cost you 4 euros to mail it to the next person on the list.
Use the PostNL app to pay, and if you don't have a printer, select the letter (350gram-2kg) and write the postzegelcode on the package. This will be 4,40 euro though.
Contents
Rules
- Receiver promises to ship the box within 24 hours again.
- Future recipient quickly passes their address to the hacker above.
- Weight should remain below 2kg.
- Play fair, this is not the meuktafel.
- Receiver promises to update the log below with a photo and some details.
- Receiver and sender take their care in disinfecting everything. There is still a pandemic raging outside.
Log / Planning
Add yourself to the bottom of the list!
Name | Photo of box contents | Received on | Shipped? | Took from box | Put in box | Any requests? |
Sebastius | - | April 2 | - | ESP12 modules, ESP32, LEDs, LEGO, Switch game, stickers, USB serial, eth0 badges, soldering iron and solder, earplugs, WAGO 221, various sensors and probably more. | - | |
f0x | April 4 | - | LEGO, Nokia screen, esp8266 modules | RevSpace SMD protoboards, dupont wires, 18650, hook-and-loop-tape, (door) magnets+sensors, devboards, otter sticker, LEDs, 433Mhz stuff, DIN-rail project casing | meer ledjes | |
Peetz0r | April 8 | April 9 |
Noor | April 14 | April 15 | USB soldering iron + wire, magnets, connector wire, LED stick, project box, stickers | LED connector wires, laptop charger tips, display badge, built-in laptop cam, ThinkGeek Timmy sticker, speech bubble stickies | USB soldering iron + wire | |
Boekenwuurm | 21 april | 21 april | sensoren, schermpje | LEDjes, sewable kitje en sensortjes die ik hier op de ooit te gebruiken lijst heb! | ||
Kartoffel | 21 april | 22 april | 18650, ESP, sensors, switch spel | USB NES gamepad, Missile cover toggle switch met LED, Wemos battery shield, Cap. touch keypad, Motor driver, USB kabel, push button | HTU21D, ESP8266 module, 18650 cel, TP4056 laad/beschermbordje, switch spel | |
Juerd | 24 april | 25 april | Lipo+laad-pcb, USB serial, Arduino Nano, BME280, DHT22, plantsensor, deurmagneten, level shifter, draadjes, headers, krimpkous, wc-papier, ledlampje antenne van RTLSDR (past niet zonder doos te slopen, wie de RTLSDR neemt kan de antenne bij me ophalen :)) |
Nieuwe doos, meukdoosvakverdeler, TCRT5000 reflectiesensor, mosfets (P, N), 47µF 25V low ESR, 10 mm RGB LED, ds18b20 temperatuursensor, drukknopje, knijper, kabelstripmesje, USB-adapter µ→C, gulden, kwartje, dubbeltje, stuiver, HNP | - | |
cmpxchg | 2 May | 3 May | see picture | could not add adalm pluto SDR transmitter/receiver, too big! :( | - | |
pepman | 5 mei | 10 mei | kabelstripmesje, Cyber stickers, Cap. touch keypad, BME280, eth0 badges, Arduino Pro Mini, HC-06 Bluetooth module | Handboortool, Tube Bizonkit, Tag, 220 μF Elco's | - | |
Pwuts | 13 mei | 18 mei | Arduino Pro Mini; HC-06 module; 220µF caps; stickers; handboortje; 2x DS18B20 (TO-92 + RVS); ESP32-WROOM; 5 SHA-badge LEDs; TCRT5000 | ESP-12E kitje; 2x Metertrekker v1.0d kitje; RFID-RC522 kitje; CR2032 (in Noors display badge); 5x WS2811 DIP LED; microswitch; chassis intrusion switch; liefde | IR photodiode/-transistor, environmental sensors, 220µF/270µF elco's ≥6.3V | |
Wheeze_NL | 22 May | 25 May | USB NES gamepad; ESP32WROOM incl. Breakout-bordje; Arduino Pro Mini; Metertrekker v1.0d kitje; chassis intrusion switch; Round PCB with LED's; some DuPont wires; DIY-Badge | USB-NFC Reader/Writer, ; Critical infra, Do not hack stickers English/German; Couldn't fit any more. |
Fun Simple Sensor | |
joepie91 | - | - | - | - | Various ICs, USB breakout modules, various stickers, whatever else I have laying around at the time, requests welcome! | Rotary encoders, RTL8710 boards, unusual buttons / solderable input devices |
Gori | - | - | - | - | - | - |
Sebastius | - | - | - | - | - | - |
You? | - | - | - | - | Random hardware bits and components | ?? |
Projects showcase
Did you do something with the stuff from the Rondreizendemeukdoos? Show us!
