StofAnanas
Project StofAnanas
Last Update 2020-04-06
The concept
The stofananas/stoflama/pmlamp shows airborne particulate matter concentration from the nearest luftdaten citizen science measurement station as a colour on a LED lamp, inspired by http://stoflamp.nl The data that the LED colour is based on is retrieved over WiFi from the luftdaten website every 5 minutes.
Features:
  • The lamp shows PM10 particulate matter concentration as a colour, from dark blue for low concentration to bright pink for high concentration
  • The lamp retrieves the PM value over wifi from the the luftdaten website, there is a one-time setup to configure your WiFi network so the device can access the internet
  • The lamp automatically determines the nearest luftdaten particulate measurement station, by doing WiFi based geolocation.
  • The number/id of the luftdaten station can also be entered manually during the one-time setup.
Ideas/nice to have:
  • Use streaming mode of ESP8266HttpClient to parse JSON directly from a stream, avoiding memory problems / stack overflows
  • Built-in web server, with links to historic measurement data of the sensor it's monitoring, link to google maps, etc.
    • complication: the nice graphs on madavi.de are based on the *hardware id* (not database id), we can't get that automatically
    • just show a table with all properties in the left column (PM values, WGS84 location) and their values in the right column?
Building it
stoflama
It consists of a few parts:
  • a Wemos D1 mini board
  • a LED shield, either the one with 1 LED, or the one with 7 LEDs
  • a plastic lamp enclosure
Steps:
  • solder the female headers onto the Wemos D1 mini, start with soldering just one pin so you can re-heat it and adjust it if the fit with the male pins is not quite right.
  • flash the firmware into the Wemos d1 mini board
  • connect the USB micro cable to the Wemos d1 mini board and verify that it works as expected
Operation Manual
stoflama
Programming
 sudo apt install python-pip
 sudo pip install platformio
Configuration
configuration
Automatic configuration:
  • power up the lamp
  • when presented with the captive portal, select a WiFi network, fill in the WiFi password, leave the luftdaten id field empty, press SAVE
  • the closest luftdaten particulate matter sensor will automatically be determined
Manual configuration:
Alternatively:
  • make sure at least the WiFi credentials have been entered and saved
  • open a console to the serial port of the wemos D1 mini (115200 bps) and enter the following command:
 config auto
  • within a few seconds, you should see it prints the current approximate geographic location and the id of the luftdaten station, the id should be non-zero. It is saved in internal memory.
Usage
  • A flashing colour (1x per second) means that something went wrong, either communication with the luftdaten server or decoding the luftdaten server response
  • WiFiManager (v 0.14) is used to manage WiFi connection to the local AP
  • ArduinoJSON (v 6.11) for the parsing the luftdaten response
  • FastLED (v 3.2.9) is used to control the RGB LED
Luftdaten interface
For example:
Colour mapping
  • 0 ug/m3: deep blue
  • 15 ug/m3: green
  • 30 ug/m3: yellow
  • 60 ug/m3: red
  • 120+ ug/m3: pink
