LichtKrant
| Project LichtKrant | |
| Controller for 3-colour 80x7 pixel moving LED sign | |
| Last Update | 2020-02-29 |
Status as of 2020/2/26:
- Reverse engineered it, I know how it works and documented it, the original controller board has been removed and replaced by an ESP8266
- Software works, allowing arbitrary bitmap graphics to be sent over WiFi. The sign can show 4-bit gradients in both red and green, essentially it now has 8-bit colors instead of 2-bit.
- UDP support has been added, allowing for sending a full 80x8 frame as rgb565 data in one UDP packet
- A new power supply has been ordered (original one was under-dimensioned for full screen graphics and broke down)
- Integration into revspace infrastructure requires more work, see below
Physical dimensions:
- 80 pixels in about 613 mm wide
- case is about 675 mm x 109 mm
- there are two screw holes on the sides, about 660mm apart
- screw holes are size M6
Reverse engineering
Processor board
It takes 5V as input.
The PCB has the following text on it: HXITC017_2.PCB
LED board
How does it work
* J1.1: IC2.A1 -> IC2.B1 -> via ... -> SRCLK signal of both column shift registers * J1.2: GND * J1.3: IC2.A2 -> IC2.B2 -> via ... -> RCLK signal of both colomn shift registers * J1.4: GND * J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green) * J1.6: GND * J1.7: IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register (red) * J1.8: GND * J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable * J1.10: VCC * J1.11: IC2.A3 (row) -> IC3.A -> row select * J1.12: VCC * J1.13: IC2.A4 (row) -> IC3.B -> row select * J1.14: VCC * J1.15: IC2.A5 (row) -> IC3.C -> row select * J1.16: J4 (IR receiver) * J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> frame enable, appears to have a pull-up already, so can be left unconnected * J1.18: ??? * J1.19: ??? * J1.20: connected to the "ethernet" dipswitch
- columns
- rows
- other
- 5V signals
- GND signals
Levels on the bus are 5V.
Theory of operation:
- next row
Timing
Columns:
Power consumption
It appears that J1.17 is used by the original control board to set the global brightness.
- all LEDs off, about 0.1 A (ESP8266 only?)
- all red LEDs on, about 3.9 A
- all green LEDs on, about 3.6 A
- all LEDs (red + green) on, about 5.8 A
- some text in red on the display, about 1.5A
Hardware modifications
- Soldered a power connector on the center of the display PCB, on the footprint that was already present. This is now the main entrance for 5V power.
- Removed the controller board
- Added a Wemos D1 mini board, it is powered with 5V from the J1 connector, pinout:
| J1 connector | Wemos D1 mini | Remark |
| J1.1 | D8 | Column data shift |
| J1.3 | D7 | Column data latch |
| J1.5 | D6 | Green data |
| J1.7 | D5 | Red data |
| J1.8 | G | Ground |
| J1.9 | D4 | Row enable |
| J1.10 | 5V | 5V from LED board to Wemos D1 mini |
| J1.11 | D3 | Row select bit 0 |
| J1.13 | D2 | Row select bit 1 |
| J1.15 | D1 | Row select bit 2 |
sudo apt install python3-pip sudo pip3 install platformio
Driving the pixels
Variable pixel brightness
Variable pixel is implemented using a kind of temporal dithering that flashes the pixels on/off:
- At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is lit on the display, otherwise it is dimmed. For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the frame frequency.
- The above is implemented for the red and green pixels separately.
UDP RGB565 interface
RAW RGB565 frames can be sent over UDP to port 1565. The blue (B) channel is ignored, as is the lowest line of the frame.
The frames can be converted from raw RGB to the RGB565 format using the ledbanner2udp program.
convert -size 80x10 -crop 80x8+0+2 -font 8-BIT\ WONDER.TTF -pointsize 9 -fill red -background black caption:"AweSome" -depth 8 rgb:- |./ledbanner2udp
convert metaballs.gif rgb:- |./ledbanner2udp
Command interpreter
This display will be used as a kind of mirror of the main LED banner, except with no blue color component and 80x7 LEDs instead of 80x8. For example, we could put it up at the kitchen and get notified of people opening doors, doorbell, etc.
Requirements
- Safe & reliable power supply, e.g. a basic Meanwell "caged" supply in a fibox
- Don't put it in the lounge, we'd like to keep the lounge clear of attention-grabbing / flashing stuff. The kitchen would be fine.
TODO
List of things to do:
- mount the thing in the *kitchen*:
- consult with revspace participants about a suitable location, suggested place is somewhere close to the patch cabinet (easier cable management)
- need mounting materials, do we have them? do we need to buy them? -> added some pieces of metal to the sides
- physical act of fixing it to something, make sure it can't just drop and injure people, damage the wall, etc.
- fix software things on the ledbanner pi, to allow forwarding image data to the led sign:
- fix fedora repository setup on the ledbanner pi (currently broken), so we can install avahi (for example) and the led sign can be addressed by its mDNS network name, "esp-ledsign.local"
- ensure a good enough WiFi connection: I (bertrik) ordered & received a couple of wemos d1 pro minis with an external antenna (at least one is in my SAMLA).
- mount the ESP8266 inside the casing, making sure the wifi antenna is clear and the d1 mini does not short-circuit
Frame forwarder
A python program (ledbanner2udp) accepts frames in the ledbanner internal frame format, converts the pixels to rgb565 (to make one frame fit in exactly one UDP packet) and forwards the frame to a configurable UDP host/port (ip address of the lichtkrant). The https://github.com/bertrik/lichtkrant/tree/ledbanner2udp branch contains arduino code to receive these frames on port 1565. The ledbanner pi has python 3.3.0 installed.
Possibly useful other info:
- https://medium.com/@tharindu_peiris/p10-led-display-panel-using-esp8266-wemos-d1-mini-nodemcu-1e463ad60722
- some fonts for rendering text on 7-pixel high https://damieng.com/blog/2011/02/20/typography-in-8-bits-system-fonts
- atari font, almost entirely 7-pixels high https://www.bigmessowires.com/atarifont.png
- Nokia 5110 7-pixel high font https://github.com/Synj24/Nokia-5110/blob/master/font.h
- Looks very similar to https://www.bax-shop.nl/lichtkrant/eurolite-esn-multicolor-lichtkrant
