DustSensor
Project Dust Sensor | |
Experiments with a dust sensor | |
Status | Completed |
Contact | bertrik |
Last Update | 2020-08-10 |
- The Plantower PMS 7003 (AliExpress link);
- The SDS011 (AliExpress link).
In parallel with the atmospheric particulate matter level measurement, my device also measures basic meteo data using a BME280 module: temperature, relative humidity and air pressure.
Future work
- build more luftdaten.info sensors and put them up in Gouda
- build a luftdaten.info sensor and put it up at RevSpace
- investigate a LoRa version of the software + TTN forwarder so we can put up a sensor at Meteo Gouda (kinderboerderij).
- can we use Cayenne as a container to carry the dust sensor data over LoRa?
Results
PMS7003
NodeMCU | PMS7003/BME280 | Remark |
PMS7003-RST | Pulled-up to 3.3V on NodeMCU side, may not be actually needed | |
PMS7003-SET | Pulled-up to 3.3V on NodeMCU side, may not be actually needed | |
D1 | PMS7003-TX | NodeMCU receive, PMS7003 transmit |
D2 | PMS7003-RX | NodeMCU transmit, PMS7003 receive |
D3 | BME280-SDA | I2C-SDA |
D4 | BME280-SCL | I2C-SCL |
GND | PMS7003-GND / BME280-GND | GND ground reference |
VU | PMS7003-VCC | USB voltage (5V) |
3.3V | BME280-VCC |
SDS011
Datasheets:
Reverse engineering:
- it contains a STM32F038K6 processor in a UFQFPN32 package.
- interesting research paper that shows some of the internals of the SDS011: https://www.researchgate.net/publication/320290219_Assessment_of_Measurement_Uncertainties_for_a_SDS011_low-cost_PM_sensor_from_the_Electronic_Signal_Processing_Perspective
- another research paper (DE version?): https://www.researchgate.net/publication/332211397_Potenzial_und_Grenzen_des_kostengunstigen_SDS011_Partikelsensors_bei_der_Uberwachung_urbaner_Luftqualitat
- The optical sensor input pin (marked magenta in the research paper above) is PA2 (pin 8)
- SWD is on pins PA13/PA14 (pin 23/34), not easily accessible from the outside
Honeywell HPMA115S
Info:
- datasheet
- data/power-plug is Molex 51021-0800
- esp arduino software for reading the SDS011 and sending it as an MQTT stream;
- arduino software for reading the PMS7003 and sending it as an MQTT stream;
- a Java based bridge application that takes the MQTT data produced by the arduino and forwards it to other backends, like the RIVM influx database, luftdaten.info API.
Dust sensor
Libraries used:
- SoftwareSerial (built-in) for serial communication with the sensor
- WiFiClient (built-in) for WiFi connectivity
- WiFiManager (tzapu) to present a captive portal and allow selection of an AP to connect to the internet
- PubSubClient (Nick O'Leary) to handle publishing of data over MQTT
- BME280I2C (Tyler Glenn) and wire for interacting with a BME280 for basic meteo data (temperature, humidity, pressure)
pio run
PMS7003
SDS011
HPMA115S
Infrastructure
The idea is that the dust sensor send its data to an MQTT server. From there on, there is an application written in Java that picks up the data from MQTT and redistributes it to other backends, like samenmeten.rivm.nl and luftdaten.info.
The topic that the sensor publishes on is
bertrik/dust/<sensorid>
where sensorid is the id of the ESP8266, in hexadecimal format, e.g. AB12CD
References
Measurement data of this particular sensor:
- Grafana page of my sensor data.
- particulate matter graphs at madavi
- humidity and pressure graphs at madavi
Overview of dust sensor types and comparisons between them:
- Page on aqicn about the PMS5003/7003
- Dutch RIVM official air quality map
- Dutch RIVM citizen science air quality map
Dust measurement blog:
Visualizing dust data
See also my Stofradar page.
Grafana
Sensor
Telegraf
Things I did:
- influxdb output plugin
- mqtt_consumer plugin
- data_format="json"
- data_type="integer"
systemctl restart telegraf
Grafana
- SELECT field(amb_pm10)
- GROUP BY
- ALIAS BY PM10
Regelgeving
Regelgeving voor fijn stof (PM10) De regelgeving voor fijn stof (PM10) kent twee doelstellingen: - Een grenswaarde voor het jaargemiddelde: 40 µg/m3 als jaargemiddelde mag niet worden overschreden. Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde beoogt vooral bescherming te bieden tegen de langetermijneffecten van fijn stof. - Een grenswaarde voor het daggemiddelde: 50 µg/m3 als daggemiddelde mag op niet meer dan 35 dagen per jaar worden overschreden. 5 Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde is vooral bedoeld om bescherming te bieden tegen de kortetermijneffecten van fijn stof.
Luftdaten.info
I'm forwarding my data also to the luftdaten.info website so it appears on the lufdaten.info map. I use the same kind of mechanism as used for RIVM: write a Java program to capture the MQTT stream and convert it to their API.
Luftdaten.info have a pretty good description of how to build your own sensor for their network. They're keeping it simple, just wire an sds011 dust sensor with some du-pont cable to a nodemcu and put it in a plastic enclosure anyone can build using some drain water piping.
It appears hack42 is also considering to join the luftdaten.info network.
protocol
Most of the Luftdaten.info upload protocols are described on the luftdaten wiki.
- data is sent as a HTTP POST to https://api.luftdaten.info/v1/push-sensor-data/ (NOTE: the trailing slash!)
- the HTTP POST uses headers "X-Pin" and "X-Sensor" (not case-sensitive it appears)
- header "X-Pin" indicates the type of data
- 1 = SDS011 or PMS7003
- 3 = BMP180
- 5 = PPD42NS
- 7 = DHT22
- 11 = BME280
- header "X-Sensor" indicates the unique sensor id, for example "esp8266-9137604"
- header "Content-Type" with value "application/json" (NOTE: API describes this header, but it's not explicitly sent by the implementations above)
- the body of the POST is JSON with the following fields:
- "software_version": string containing the software version of the sender, for example "python-dusty 0.0.1"
- "sensordatavalues": array of structures containing measurement data, looking like this:
- "value_type" (when X-PIN=1): string describing the measurement item type, can be "P1" (PM10 value) or "P2" (PM2.5 value) with dust value in ug/m3. It appears there is also an unofficial "P0" field which encodes for the PM1.0 value.
- "value_type" (when X-PIN=7): string describing the measurement item type, can be "temperature", "humidity"
- "value_type" (when X-PIN=11): string describing the measurement item type, can be "temperature", "pressure", "humidity"
- "value": field containing the measurement value (NOTE: in string quotes, not as numeric values!)
Other meta-information like latitude/longitude of the sensor is sent by an e-mail registration process. This is linked to your measurements by means of the unique sensor id.
Revspace particulate matter sensor
The idea is to put up particulate matter sensors up at RevSpace.
Stuff to figure out:
- firmware (the easy part)
- a place to put up the sensor(s), one in each room?
- how many does revspace need/want?
- a PCB?
- a housing for the sensors, could be laser cut or 3d-printed
- financing:
- create a cost estimate
- get financing in advance to avoid spending a lot of personal money on a project that might not complete because of external dependencies
Proposal:
- build a bunch of PM sensors, each containing an ESP8266 + PMS7003 particulate matter sensor + BME280 humidity/temperature sensor
- PMS7003 is *not* the "default" luftdaten sensor (SDS011), but it is supported, actually reports a bit more (particle counts, PM1.0)
- BME280 is used to measure humidity, so we can correct for that. As a side effect, we get (case) temperature and atmospheric pressure.
- the sensor reports particulate matter concentration over revspace MQTT, at a regular interval
- preferably make it "Luftdaten compatible" too so it can run the luftdaten firmware (with automatic updates)
- get extra parts for one more complete module, that will be the development model
- get extra parts for one more complete module, to participate as a Luftdaten sensor
