DustSensor
Revision as of 12:24, 23 February 2020 by Bertrik Sikken (talk | contribs) (SDS011)
Project Dust Sensor
Last Update 2020-02-23
PM10 in the morning of 2018-06-03
PM10 at around 2018-06-03 20:50 UTC
In parallel with the atmospheric particulate matter level measurement, my device also measures basic meteo data using a BME280 module: temperature, relative humidity and air pressure.
Future work
  • build more luftdaten.info sensors and put them up in Gouda
  • build a luftdaten.info sensor and put it up at RevSpace
  • investigate a LoRa version of the software + TTN forwarder so we can put up a sensor at Meteo Gouda (kinderboerderij).
  • can we use Cayenne as a container to carry the dust sensor data over LoRa?
Results
PMS7003
Connections
NodeMCU PMS7003/BME280 Remark
PMS7003-RST Pulled-up to 3.3V on NodeMCU side, may not be actually needed
PMS7003-SET Pulled-up to 3.3V on NodeMCU side, may not be actually needed
D1 PMS7003-TX NodeMCU receive, PMS7003 transmit
D2 PMS7003-RX NodeMCU transmit, PMS7003 receive
D3 BME280-SDA I2C-SDA
D4 BME280-SCL I2C-SCL
3.3V BME280-VCC
SDS011
image from SDS research paper showing the STM32F038K6 processor
STM32F038K6_pinout
Datasheets:
Reverse engineering:
Dust sensor
Libraries used:
  • SoftwareSerial (built-in) for serial communication with the sensor
  • WiFiClient (built-in) for WiFi connectivity
  • WiFiManager (tzapu) to present a captive portal and allow selection of an AP to connect to the internet
  • PubSubClient (Nick O'Leary) to handle publishing of data over MQTT
  • BME280I2C (Tyler Glenn) and wire for interacting with a BME280 for basic meteo data (temperature, humidity, pressure)
 pio run
PMS7003
SDS011
Infrastructure
The idea is that the dust sensor send its data to an MQTT server. From there on, there is an application written in Java that picks up the data from MQTT and redistributes it to other backends, like samenmeten.rivm.nl and luftdaten.info.
The topic that the sensor publishes on is
 bertrik/dust/<sensorid>
where sensorid is the id of the ESP8266, in hexadecimal format, e.g. AB12CD
References
Measurement data of this particular sensor:
Overview of dust sensor types and comparisons between them:
Dust measurement blog:
Visualizing dust data
See also my Stofradar page.
Grafana
Sensor
Telegraf
Things I did:
    • influxdb output plugin
    • mqtt_consumer plugin
      • data_format="json"
      • data_type="integer"
  systemctl restart telegraf
Grafana
  • SELECT field(amb_pm10)
  • GROUP BY
  • ALIAS BY PM10
Regelgeving
Luftdaten.info
I'm forwarding my data also to the luftdaten.info website so it appears on the lufdaten.info map. I use the same kind of mechanism as used for RIVM: write a Java program to capture the MQTT stream and convert it to their API.
Luftdaten.info have a pretty good description of how to build your own sensor for their network. They're keeping it simple, just wire an sds011 dust sensor with some du-pont cable to a nodemcu and put it in a plastic enclosure anyone can build using some drain water piping.
It appears hack42 is also considering to join the luftdaten.info network.
protocol
Most of the Luftdaten.info upload protocols are described on the luftdaten wiki.
  • data is sent as a HTTP POST to https://api.luftdaten.info/v1/push-sensor-data/ (NOTE: the trailing slash!)
  • the HTTP POST uses headers "X-Pin" and "X-Sensor" (not case-sensitive it appears)
    • header "X-Pin" indicates the type of data
      • 1 = SDS011 or PMS7003
      • 3 = BMP180
      • 5 = PPD42NS
      • 7 = DHT22
      • 11 = BME280
    • header "X-Sensor" indicates the unique sensor id, for example "esp8266-9137604"
    • header "Content-Type" with value "application/json" (NOTE: API describes this header, but it's not explicitly sent by the implementations above)
    • "software_version": string containing the software version of the sender, for example "python-dusty 0.0.1"
      • "value_type" (when X-PIN=1): string describing the measurement item type, can be "P1" (PM10 value) or "P2" (PM2.5 value) with dust value in ug/m3. It appears there is also an unofficial "P0" field which encodes for the PM1.0 value.
      • "value_type" (when X-PIN=7): string describing the measurement item type, can be "temperature", "humidity"
      • "value": field containing the measurement value (NOTE: in string quotes, not as numeric values!)
Other meta-information like latitude/longitude of the sensor is sent by an e-mail registration process. This is linked to your measurements by means of the unique sensor id.
Revspace particulate matter sensor
The idea is to put up a particulate matter sensor up at RevSpace and register it with luftdaten, so it can be used in the luftdaten and RIVM samenmeten citizen-science projects.
Things preventing completion of this sub-project:
  • it is not clear whether we can actually put up the proposed PM sensor enclosure (too ugly or something, who decides this?)
  • I (bertrik) no longer have notes of who helps to fund a RevSpace particulate matter sensor
Access it locally as http://ESP_B74C71/ ? Feinstaubsensor-12012657
Madavi data:
