LED skirt
Versie door Noor (overleg | bijdragen) op 26 feb 2020 om 21:00
Project LED-skirt
Contact Noor
Last Update 2020-02-26
To do
  • Reinforce wire connections with hot glue and/or zip ties.
  • Punch and grommet holes where velcro used to be.
  • Make LEDs addressable by position.
  • More programming designs.
  • Get aurora borealis palette working properly on circles and panel, and shooting stars display on strips.
  • Replace (or add to) strip in bottom tube with side-emitting LEDs?
LED count
  • 240 - circles (all used except one)
  • 64 - 8x8 panel.
  • 23 - strip 1.
  • 23 - strip 2.
  • 17 - strip 3.
  • 84 (?) - strip along bottom tube.
Total: 451 LEDs.
Timeline
Construction
2019-11-06 - 2019-11-11
Bought:
Old sketches:
2019-11-12 - 2019-11-24
  • Played with layout of LEDs, waiting for items to arrive.
  • Tested out LEDs under layers and on crinoline.
2019-11-25
  • Took apart seams of inner layers of black skirt to add extra panels to fit over crinoline.
2019-11-26
  • Measured skirt on top of crinoline. Extra panel with bottom arc length of 100+cm.
  • Decided to go with 6 strips of 23 LEDs each. Cut one strip.
2019-12-03 - 2019-12-05
  • Tested out LED rings. One wire was detached so had to be soldered on.
2019-12-06
  • Punched holes in crinoline, used zip ties to attach first LED strip.
  • Took apart LED circles and tested FastLED programs.
  • Set up LED circles, one strip, and panel together on crinoline and used zip ties to place everything but the panel on crinoline.
  • Ran FastLED programs on everything together.
  • Pictures posted by others to Facebook, RevSpace kiekjes, Twitter.
2019-12-20
  • Rearranged LED circles, mounted some back on with velcro. Mounted panel with velcro.
  • Cut two more strips. Attached wires to one and mounted it horizontally at an angle.
2019-12-22
  • Folded up bottom hem and put velcro strips all across to partially make a tube along bottom.
2019-12-24
2019-12-25
  • Measured and cut panel for black layer of skirt.
2020-01-10
  • Used fabric glue along bottom hem tube, in between velcro strips.
  • Soldered wires to more LED strips.
2020-01-11
  • Soldered wires to remaining LED strips.
  • Connected everything together, hooked up to an Arduino.
2020-01-17
  • Added more velcro bits to fix placement of LEDs.
  • Experimented with modifying FastLED programs. BPM on circles?
2020-01-18 - 2020-02-13
  • Experimented more with FastLED programs.
  • For custom color palettes, used PaletteKnife bookmarklet to generate codes for palettes. Add to sketch directly, or add to Arduino/libraries/FastLED/colorpalettes.cpp and palette name to colorpalettes.h.
  • Cut up plastic bag for panel over skirt, attached with velcro.
  • Finished up everything on black outer skirt.
  • Bought 2x SilverCrest power banks.
HackerHotel 2020
2020-02-14 -2020-02-16
  • Debut as Princess of Lights went excellent, with paparazzi taking pictures and video all weekend.
  • About a dozen wires broke off throughout the weekend and had to be soldered back on, some with reinforcements of zip ties to hold them in place.
  • LEDs kept weighing down crinoline, and since the string in the waist came out a long time ago, the velcro was not enough to hold it up. Used an opened paperclip to hold it together, and then a safety pin. Need to add a hook fastener, or use a large safety pin (through grommeted holes) or some other kind of fastener.
Modified fastLED sketches that I used at HH2020:
Arduino 1 (for circles and panel):
#include <FastLED.h>
FASTLED_USING_NAMESPACE
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN    6
//#define CLK_PIN   4
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
#define NUM_LEDS    304
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          15
#define FRAMES_PER_SECOND  120
#define SHIFT_PER_SECOND  15
void setup() {
  delay(3000); // 3 second delay for recovery
  // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbowWithGlitter, bpm, confetti, flowingwater };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
DEFINE_GRADIENT_PALETTE( Aleutian_Clouds_gp ) {
    0,  37,184,133,
   12,  37,184,133,
   25,  46,168, 98,
   37,  55,152, 67,
   51,  22,104, 77,
   63,   5, 66, 88,
   76,   1, 31, 49,
   88,   1, 19, 32,
  100,   1,  2, 11,
  112,   1,  3,  9,
  125,   1,  6,  20,
  137,   1,  10, 20,
  149,   1,  2, 11,
  161,   1,  19, 32,
  173,   1, 31, 49,
  185,   5, 66, 88,
  200,  22,104, 77,
  212,  55,152, 67,
  225,  46,168, 98,
  237,  37,184,133,
  255,  37,184,133,
void loop()
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  // send the 'leds' array out to the actual LED strip
  FastLED.show();
  // insert a delay to keep the framerate modest
  FastLED.delay(1000/FRAMES_PER_SECOND);
  // do some periodic updates
  EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
  EVERY_N_SECONDS( 10 ) { nextPattern(); } // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
  // FastLED's built-in rainbow generator
  fill_rainbow( leds, NUM_LEDS, gHue, 35);
void rainbowWithGlitter()
  // built-in FastLED rainbow, plus some random sparkly glitter
  rainbow();
  addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
  if( random8() < chanceOfGlitter) {
    leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
  // random colored speckles that blink in and fade smoothly
  fadeToBlackBy( leds, NUM_LEDS, 10);
  int pos = random16(NUM_LEDS);
  leds[pos] += CHSV( gHue + random8(64), 200, 255);
void bpm()
  // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
  uint8_t BeatsPerMinute = 62;
  CRGBPalette16 palette = PartyColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
  for( int i = 0; i < NUM_LEDS; i++) { //9948
    leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
int offset = 0;
int framecounter = 0;
void flowingwater()
  CRGBPalette16 palette = Aleutian_Clouds_gp;
    leds[i] = ColorFromPalette(palette, ((i+offset)%256), 128);
      addGlitter(1);
  framecounter++;
  if (framecounter > FRAMES_PER_SECOND / SHIFT_PER_SECOND) {
  offset++;
  //offset = offset + random8(4);
  if (offset >= 256) {
    offset = 0;
  framecounter = 0;
Arduino 2 (for strips), from fastLED's demo reel:
#endif
#define DATA_PIN    6
//#define CLK_PIN   4
#define NUM_LEDS    147
#define BRIGHTNESS          75
#define FRAMES_PER_SECOND  40
void setup() {
SimplePatternList gPatterns = { confetti, sinelon, juggle, bpm };
void loop()
  FastLED.show();
void nextPattern()
void confetti()
void sinelon()
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, 20);
  int pos = beatsin16( 13, 0, NUM_LEDS-1 );
  leds[pos] += CHSV( gHue, 255, 192);
void bpm()
void juggle() {
  // eight colored dots, weaving in and out of sync with each other
  byte dothue = 0;
  for( int i = 0; i < 8; i++) {
    leds[beatsin16( i+7, 0, NUM_LEDS-1 )] |= CHSV(dothue, 200, 255);
    dothue += 32;
Further work
2020-02-21 and 2020-02-25
  • Removed velcro pads from skirt as they were coming apart and were useless at Hacker Hotel.
  • Applied Mod Podge where velcro pads used to be, sealing loose threads.
