LichtKrant
Project LichtKrant
Controller for 3-colour 80x7 pixel moving LED sign
Last Update 2019-12-31
It is 80 pixels wide, 7 pixels high. Each pixel has two sub-pixels (red and green), so it can display 3 colours (off, red, orange, green)
Goals:
  • reverse engineer the electronics and document how it works -> DONE
  • replace the controller board with an ESP, so we can receive image/text updates over the network -> DONE
  • implement more colour depth, so we can display gradient bitmaps (not just red, green, orange) -> DONE
  • write software for this, so other people can do the same for their display -> IN PROGRESS
Next:
  • pixelflut server, as described here, just skip the blue channel
  • getting it to work on a network, see if it impacts performance, visual quality
Future ideas:
  • generic receiver process for image frames (80x7 RGB, in UDP or TCP/IP)
  • replicate the existing 80x8 display at revspace, but with one less row and no blue LEDs
  • double buffering, or some other kind of sync mechanism/callback?
Reverse engineering
lichtkrantconnector
Processor board
It takes 5V as input.
LED board
How does it work
*  J1.1: IC2.A1 -> IC2.B1 -> via ... -> shift clock
*  J1.2: GND
*  J1.3: IC2.A2 -> IC2.B2 -> via ... -> latch clock
*                      IC1.B2 -> IC1.A2 -> U11.RCLK
*                      IC1.B5 -> IC1.A5 -> U1.RCLK
*  J1.4: GND
*  J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green)
*  J1.6: GND
*  J1.7: IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register (red)
*  J1.8: GND
*  J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable
         IC4.1A -> IC4.1Y -> IC3.G2B
* J1.10: VCC
* J1.12: VCC
* J1.14: VCC
* J1.16: J4 (IR receiver)
* J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> row enable?
* J1.18: ???
* J1.19: ???
  • columns
  • rows
  • other
    • 5V signals
    • GND signals
Levels on the bus are 5V.
Theory of operation:
  • next row
Timing
Columns:
Power consumption
The duty cycle of the LEDs is strongly determined by the row enable pins. It appears that J1.17 is used by the original control board to set the global brightness.
  • all LEDs off, about 20 mA
  • all red LEDs on, about 4.0 A
  • all green LEDs on, about 3.7 A
  • all LEDs (red + green) on, about 6.4 A
Hardware modifications
Wemos D1 mini as sign controller
  • added a power connector on the footprint that was already present, 5V is supplied there (up to 6 Amps!)
  • removed the controller board
  • added a Wemos D1 mini board, see the source code (leddriver.cpp) for the pinout
Pinout
Connections
J1 connector Wemos D1 mini Remark
J1.1 D8 Row shift
J1.3 D7 Row latch
J1.5 D6 Green data
J1.7 D5 Red data
J1.8 G Ground
J1.9 D4 Row enable
J1.10 5V 5V from LED board to Wemos D1 mini
J1.11 D3 Col select bit 0
J1.13 D2 Col select bit 1
J1.15 D1 Col select bit 2
Preliminary code can be found on the github lichtkrant repository.
The moving LED sign is driven using an ESP8266.
The LED driver handles one line at a time. It is driven by the interrupt handler of timer1.
The way, we get steady timing for real-time driving of the display. The main execution context is still free to do other stuff.
Variable pixel brightness
Variable pixel is implemented using a kind of duty-cycle/dithering modulation:
  • At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is lit on the display, otherwise it is dimmed. For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the update frequency.
  • The above is implemented for the red and green pixels separately.
RAW RGB interface
RAW RGB frames (80x7x3 bytes) can be sent over TCP to port 1234. The blue (B) channel is ignored.
 convert -size 80x10 -crop 80x7+0+3 -font 8-BIT\ WONDER.TTF -pointsize 10 -fill red -background black caption:"AweSome" -depth 8 rgb:- |netcat esp-ledsign.local 1234
 convert metaballs.gif -crop 80x7+0 rgb:- |netcat esp-ledsign.local 1234
Possibly useful other info:
