LichtKrant
| Project LichtKrant | |
| Controller for 3-colour 80x7 pixel moving LED sign | |
| Last Update | 2019-12-23 |
It is 80 pixels wide, 7 pixels high. Each pixel has two sub-pixels (red and green), so it can display 3 colours (off, red, orange, green)
Goals:
- reverse engineer the electronics and document how it works
- replace the controller board with an ESP, so we can receive image/text updates over the network
- implement more colour depth, so we can display gradient bitmaps (not just red, green, orange)
- write software for this, so other people can do the same for their display
Ideas:
- replicate the existing 80x8 display at revspace, but with one less row and no blue LEDs
- implement a pixelflut server, e.g. pretend to be RGB and just skip the blue channel
- double buffering, or some other kind of sync mechanism/callback?
Short term improvements:
- pixelflut server
- generic receiver process for image frames (80x7 RGB, in UDP or TCP/IP)
Reverse engineering
Processor board
It takes 5V as input.
LED board
How does it work
*  J1.1: IC2.A1 -> IC2.B1 -> via ... -> shift clock
*  J1.2: GND
*  J1.3: IC2.A2 -> IC2.B2 -> via ... -> latch clock
*                      IC1.B2 -> IC1.A2 -> U11.RCLK
*                      IC1.B5 -> IC1.A5 -> U1.RCLK
*  J1.4: GND
*  J1.5: IC1.B3 -> IC1.A3 -> U11.SER -> data pin for upper shift register (green)
*  J1.6: GND
*  J1.7: IC1.B4 -> IC1.A4 -> U1.SER -> data pin for lower shift register (red)
*  J1.8: GND
*  J1.9: IC2.A7 -> IC2.B7 -> via ... -> row enable
         IC4.1A -> IC4.1Y -> IC3.G2B
* J1.10: VCC
* J1.12: VCC
* J1.14: VCC
* J1.16: J4 (IR receiver)
* J1.17: IC2.A6 -> IC2.B6 -> IC3.G2A -> row enable?
* J1.18: ???
* J1.19: ???
- columns
- rows
- other
- 5V signals
- GND signals
Levels on the bus are 5V.
Theory of operation:
- next row
Timing
Columns:
Power consumption
The duty cycle of the LEDs is strongly determined by the row enable pins. It appears that J1.17 is used by the original control board to set the global brightness.
- all LEDs off, about 20 mA
- all red LEDs on, about 4.0 A
- all green LEDs on, about 3.7 A
- all LEDs (red + green) on, about 6.4 A
Hardware modifications
- added a power connector on the footprint that was already present, 5V is supplied there (up to 6 Amps!)
- removed the controller board
- added a Wemos D1 mini board, see the source code (leddriver.cpp) for the pinout
Preliminary code can be found on the github lichtkrant repository.
The plan is to drive the display using an ESP32, which is a dual-core processor. One core is dedicated entirely to driving the display in real-time so the other core is free to do other non time-critical tasks (e.g. receiving messages over the network).
Communication between the cores consists purely of the state of the frame buffer. The main core writes the frame buffer, the real-time display core reads the frame buffer and updates the LEDs.
Alternative: Run the real-time part in an interrupt, leave the "main-loop" for non time-critical tasks. This is what is implemented in the esp8266 branch of the software archive, currently targeted at an ESP8266 even.
variable pixel brightness
Variable pixel brightness is planned using a kind of duty-cycle/dithering modulation:
- At each frame start, for each pixel, we add the brightness value from the frame buffer to the brightness count (e.g. 0-255). If the addition results in an overflow, the pixel is lit on the display, otherwise it is dimmed.
For example, adding a brightness value of 128 causes the addition to overflow every other time, causing a 50%/50% duty cycle at half the update frequency.
This is a kind of real-time dithering algorithm, the brightness count represents the error between the displayed brightness (on or off) and the desired brightness (value 0..255).
frame rate
The achievable frame rate is limited by the shift clock rate, suppose this is 1 MHz. One frame takes 80x7 = 560 clocks, or 0.56 milliseconds, or equivalently the framerate is 1785 Hz maximum.
- a pixel at 1/256 brightness (lowest) would flash with a rate of about 7 Hz.
- a pixel at 4/256 brightness would flash with a tolerable rate of about 28 Hz.
- a pixel at 8/256 brightness would flash with a tolerable rate of about 56 Hz.
- a pixel at quarter brightness (64/256) would flash with a rate of about 446 Hz.
- a pixel at medium brightness (128/256) would flash with a rate of about 892 Hz.
So it looks like we can get about 5 bits of brightness (32 levels) out of it and still have tolerable flashing rates (higher > 50 Hz).
Possibly useful other info:
