LichtKrant
| Project LichtKrant | |
| 350px | |
| Some 3-colour 80x7 pixel moving LED sign | |
| Status | Initializing |
| Last Update | 2019-12-16 |
Found this moving LED sign on the revspace free stuff table.
It is 80 pixels wide, 7 pixels high. Each pixel has two sub-pixels (red and green), so it can display 3 colours (off, red, orange, green)
Goals:
- reverse engineer the electronics and document how it works
- replace the controller board with an ESP32, so we can receive image/text updates over the network
- implement more colour depth, so we can display gradient bitmaps (not just red, green, orange)
- write software for this, so other people can do the same for their display
Processor board
It takes 5V as input.
Connector pinout J1
*  J1: pin IC5.A8 -> IC2.A1 -> IC2.B1 -> via ...
*  J2: GND?
*  J3: pin IC6.A1 -> IC2.A2 -> IC2.B2 -> via ...
*                    IC1.B2 -> IC1.A2 -> U11.RCLK
*                    IC1.B5 -> IC1.A5 -> U1.RCLK
*  J4: GND?
*  J5: pin IC6.A2 -> IC1.B3 -> IC1.A3 -> U11.SER
*  J6: GND?
*  J7: pin IC6.A3 -> IC1.B4 -> IC1.A4 -> U1.SER
*  J8: GND?
*  J9: pin IC6.A4 -> IC2.A7 -> IC2.B7 -> via ...
                  -> IC4.1A -> IC4.1Y -> IC3.G2B
* J10: VCC?
* J11: pin IC6.A5 -> IC2.A3 (row) -> IC3.A
* J12: VCC?
* J13: pin IC6.A6 -> IC2.A4 (row) -> IC3.B
* J14: VCC?
* J15: pin IC6.A7 -> IC2.A5 (row) -> IC3.C
* J16: ???
* J17: pin IC6.A8 -> IC2.A6 -> IC2.B6 -> IC3.G2A
* J18: ???
* J19: ???
* J20: connected to the "ethernet" dipswitch
IC2.A7 <- IC4.1A <- via
- IC1 = 74HC245 (oct buf)
- IC2 = 74HC245 (oct buf)
- IC3 = 74HC138 (3-8 mux)
- IC4 = 74HC04 (hex inverter)
- IC5 = 74HC245 (oct buf) on CPU board
- IC6 = 74HC245 (oct buf) on CPU board
- U1 = lower chain of 595
- U11 = upper chain of 595
There are 8 rows (3 bits). Two chains of 10x595 (each) for the columns, U11-U10 and U11-U20.
In summary.
- rows
- 3-bits row select
- columns
- 1 bit shift clock shared for both shift registers
- 1 bit shift register latch bit shared for both shift registers
- 1 data bit for 80-bit shift register 1
- 1 data bit for 80-bit shift register 2
Levels on the bus are 5V (so can we drive it with an ESP?)
LED board
The are already electronics on it, consisting mostly of 595 chips (serial shift registers). The are two chains of 10 pieces of 74hc595 chips each, controlling the columns.
There is an '138 chip (3-to-8 decoder) that drives a set of MOSFETS, 7 in total, controlling the rows.
The MOSFETs are SDM4953, dual P-channel MOSFETs.
The plan is to drive the display using an ESP32, with one core dedicated to the display and the other free to do other stuff (e.g. receiving messages over the network).
Brightness is done using a kind of PWM:
- For each frame we add to it the brightness value from the frame buffer (e.g. 0-256). If the addition results in an overflow, the pixel is lit on the display. If no overflow occurs, the pixel is dimmed on the display.
- Each pixel on the display starts with a random count, so we avoid synchronised flashing of the pixels on the display. In other words, pixels with the same brightness has the same duty cycle, but have random turn-of/turn-off times with respect to each other.
Communication between the cores consists purely of the state of the frame buffer. The main core writes the frame buffer, the real-time core reads the frame buffer.
Possibly useful other info:
