LichtKrant
Project LichtKrant
350px
Some 3-colour 80x7 pixel moving LED sign
Status Initializing
Last Update 2019-12-15
Found this lichtkrant on the revspace free stuff table.
It is 80 pixels wide, 7 pixels high. Each pixel has two sub-pixels (red and green), so it should be possible to display at least 3 colours (red, orange, green)
Goals:
  • investigate if we can drive this with an ESP8266
  • investigate whether we can apply some kind of PWM to increase colour depth
  • document how it works
  • write software for this, so other people can do the same for their display
lichtkrantconnector
Processor board
It takes 5V as input.
Connector pinout J1
*  J1: pin IC5.A8 -> IC2.A1 -> IC2.B1 -> via ...
*  J2: GND?
*  J3: pin IC6.A1 -> IC2.A2 -> IC2.B2 -> via ...
*                    IC1.B2 -> IC1.A2 -> U11.RCLK
*                    IC1.B5 -> IC1.A5 -> U1.RCLK
*  J4: GND
*  J5: pin IC6.A2 -> IC1.B3 -> IC1.A3 -> U11.SER
*  J6:
*  J7: pin IC6.A3 -> IC1.B4 -> IC1.A4 -> U1.SER
*  J8:
*  J9: pin IC6.A4 -> IC2.A7
* J10:
* J11: pin IC6.A5 -> IC2.A3 (row) -> IC3.A
* J12:
* J13: pin IC6.A6 -> IC2.A4 (row) -> IC3.B
* J14:
* J15: pin IC6.A7 -> IC2.A5 (row) -> IC3.C
* J16:
* J17: pin IC6.A8 -> IC2.A6
* J18:
* J19: 5V
* J20: connected to the "ethernet" dipswitch
IC2 to IC3
* IC2.B1 -> IC3.
IC1 = 245 (oct buf) IC2 = 245 (LED board oct buf) IC4 = 138 (3-8 demux) IC5 = 245 (oct buf) IC6 = 245 (oct buf)
There are 8 rows (3 bits). Two chains of 10x595 (each) for the columns.
So it basically looks like a 9 bit bus.
  • 3-bits row select
Levels on the bus are 5V (so can we drive it with an ESP?)
LED board
The LED board contains the actual pixels, organized in 16 modules of 5x7 LEDs. Each LED has a red sub-pixel and a green sub-pixel, so it can do colors: red, green, orang The LED modules have the text GYXM-G2357ASRG on them.
The are already electronics on it, consisting mostly of 595 chips (serial shift registers).
There is an '138 chip (3-to-8 decoder) that drives a set of MOSFETS, 7 in total, so probably the row select.
The MOSFETs are SDM4953, dual P-channel MOSFETs.
Possibly useful other info:
