LED skirt
Revision as of 01:50, 8 December 2019 by Noor (talk | contribs)
Project LED-skirt
Contact Noor
Last Update 2019-12-08
To do
  • Cut up rest of LED strip into sections of 23 LEDs.
  • Fix rest of LED strips onto crinoline.
  • Microcontrollers and wiring.
  • Figure out how much power is needed and battery holders.
  • Want side-emitting LEDs along the bottom, but can't find side-emitting LEDs that are also waterproof, and can't put more than 1m of non-waterproof ones in a silicon tube.
  • Diameter of crinoline bottom hoop is 80 cm. Need to add an extra 100+cm of arc length of black paneling and tulle paneling to inner layers.
Timeline
2019-11-06 - 2019-11-11
Bought:
2019-11-12 - 2019-11-24
  • Layout of LEDs, waiting for items to arrive.
  • Tested out LEDs under layers and on crinoline.
2019-11-25
  • Took apart seams of inner layers of black skirt to add extra panels to fit over crinoline.
2019-11-26
  • Measured skirt on top of crinoline. Extra panel with bottom arc length of 100+cm.
  • Decided to go with 6 strips of 23 LEDs each. Cut one strip.
2019-12-06
  • Punched holes in crinoline, used zip ties to attach first LED strip.
  • Took apart LED circles.
  • Set up LED circles, one strip, and panel together on crinoline and used zip ties to place everything but the panel on crinoline.
  • Pictures posted by others to Facebook, RevSpace kiekjes, Twitter.
Pictures
