StofAnanas
Project StofAnanas
Last Update 2019-07-03
The idea
Show current airborne particulate matter concentration using a LED light in a lamp, inspired by http://stoflamp.nl The data that the LED colour is based on is simply retrieved over WiFi from the luftdaten website.
Features:
  • The lamp shows PM10 particulate matter concentration as a colour, from dark blue for low concentration to bright pink for high concentration
  • The lamp retrieves the PM value over wifi from the the luftdaten website, there is a one-time setup to configure your WiFi network so the device can access the internet
  • The number/id of the luftdaten station used for the PM concentration can to be entered during the one-time setup.
  • If no luftdaten station id is entered, the station id is determined automatically by WiFi geolocation!
  • The hardware setup is compatible with Wemos D1 RGB LED shields. My PL9823 LED is compatible with the WS2812B LED driver.
Ideas/nice to have:
  • The lamp "breathes" by varying the intensity over time, e.g. a cycle of 10 seconds where the light dims a bit and brightens a bit
    • perhaps increase the breathing rate for higher PM?
    • perhaps modulate the colour saturation instead of intensity?
  • Remote control over IR?
Operation Manual
configuration
Programming
Configuration
Automatic configuration:
  • move close to the particulate matter sensor (< 100 meters), power up the lamp
  • on a mobile phone, connect to the "ESP-STOFANANAS" network, and select login
  • when presented with the captive portal, select a WiFi network, fill in the WiFi password, leave the luftdaten id field empty, press SAVE
  • the closest particulate matter sensor will automatically be determined
Manual configuration:
Alternatively:
  • move close to the particulate matter sensor (< 100 meters) and make sure at least the WiFi credentials have been entered and saved
  • open a console to the serial port (115200 bps) and enter the following command:
 config auto
  • within a few seconds, you should see it prints the current approximate geographic location and the id of the luftdaten station, the id should be non-zero
Usage
  • Power up the lamp while in range of the WiFi network you configured
  • The LED should start yellow (connecting to the WiFi), then briefly change to OFF (retrieving PM value from Luftdaten), then change to a colour representing a PM concentration
  • A new PM measurement is retrieved every 5 minutes.
pinout
The lamp is controlled by an ESP8266, a Wemos D1 mini board. The LED is an RGB LED with built-in PL9823 controller. The PL9823 is compatible with the WS2812B RGB LED as far as I can tell (the WS2812B driver in the FastLED library works with the PL9823).
Connections (using dupont female-female):
  • LED Din to Wemos D1 mini pin D2
  • LED Gnd to Wemos D1 mini pin GND
  • LED Vdd to Wemos D1 mini pin 5V
This is the same pinout as used by the Wemos WS2812B RGB shield
  • WiFiManager (v 0.14) is used to manage WiFi connection to the local AP
  • ArduinoJSON (v 6.11) for the parsing the luftdaten response
  • FastLED (v 3.2.9) is used to control the RGB LED
Luftdaten interface
For example:
Colour mapping
  • 0 ug/m3: deep blue
  • 25 ug/m3: green
  • 50 ug/m3: yellow
  • 100 ug/m3: red
  • 200 ug/m3: (and higher)purplish
