StofAnanas
Project StofAnanas
Last Update 2019-06-18
The idea
Show current airborne particulate matter concentration using a LED light in a lamp, inspired by http://stoflamp.nl The data that the LED colour is based on is simply retrieved over WiFi from the luftdaten website.
This lamp is a plastic pine apple ("ananas"), bought at the "Action" store.
Features:
  • The lamp shows particulate matter concentration as a colour, from light blue for low concentration and bright pink for high concentration
  • The lamp retrieves the PM value over wifi from the the luftdaten website
  • The luftdaten measurement station can be entered at the same time as when wifi credentials are entered.
Ideas/nice to have:
  • The lamp "breathes" by varying the intensity over time, e.g. a cycle of 10 seconds where the light dims a bit and brightens a bit. Perhaps increase the breathing rate for higher PM.
  • Automatic determination of location by means of wifi location
  • Remote control over IR
  • Use HSV/HSL colour model internally (instead of RGB)
Operation Manual
configuration
Programming
Configuration
  • on a mobile phone, connect to the "ESP-STOFANANAS" network, and select login
  • NOTE: when the configuration is ongoing, the LED will be YELLOW, it turns OFF when configuration is done.
pinout
The lamp is controlled by an ESP8266, a Wemos D1 mini board. The LEDs is an RGB LED with built-in PL9823 controller.
Connections (using dupont female-female):
  • LED Din to Wemos D1 mini pin D3
  • LED Gnd to Wemos D1 mini pin GND
  • LED Vdd to Wemos D1 mini pin 5V
Software is available on github.
Luftdaten interface
The current measurement value of a particular sensor can be retrieved over a REST interface, by performing an HTTP GET on URL
For example:
Arduino libraries
Libraries:
  • WiFiManager is used to manage WiFi connection to the local AP
  • FastLED is used to control the LED
  • ArduinoJSON for the parsing the luftdaten response
