LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2019-04-25
The idea
  • a forwarder application that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but it appears there is no universal solution. I am publishing all source code on github and will put up documentation on this wiki. Everyone invents their own payload format, something more universal like Cayenne LPP would be nice. However I could not find a way to encode particulate matter data using Cayenne, so I'll just invent my own payload format too.
This has been done by:
One thing in particular I'd like to do better than existing solutions is to use proper OTAA for the LoRa connection to TTN. OTAA means over-the-air-activation and is a mechanism to dynamically negotiate communication/encryption keys instead of programmed specifically in each sensor node. Once the OTAA is done successfully, the node remembers device address, session keys, etc for future communication.
This makes it possible to have a single firmware image for all sensor nodes and it simplifies the setup:
  • the node shows its unique id on the OLED
  • at the TTN console, you register a new device with the unique id
  • done!
  • Investigate failing re-joins that seem to happen sometimes after the node has been online for a while
  • Implement a kind of schedule: turn the sds011 on, wait some time, take a measurement, turn it off, wait for some time
    • make this match the TTN send schedule? it's useless to do a measurement if we don't have TTN airtime to transmit it
  • Finish the Java software (MQTT listener, payload decoder, luftdaten forwarder)
    • I don't know what kind of id I can use towards Luftdaten, the regular convention is "esp8266-XXXX", where XXXX is the unique ESP id, but obviously my node is not an ESP8266.
The node is based on Arduino, in particular a TTGO ESP32 board with onboard SX1276 LoRa chip. The sensor is an SDS-011, just like in the luftdaten project. For humidity/temperature, I'd like to use a BME280.
NOTE: https://www.thethingsnetwork.org/community/berlin/post/warning-attention-users-of-ttgo21-v16-boards-labeled-t3_v16-on-pcb-battery-exploded-and-got-on-fire
  • SDS011 5V to ESP32 5V
  • SDS011 GND to ESP32 GND
  • SDS011 TXD to ESP32 GPIO35 (maybe I can find two suitable pins close together)
  • SDS011 RXD to ESP32 GPIO25 (maybe I can find two suitable pins close together)
  • BME280 3V todo
  • BME280 SDA todo
  • BME280 SCL todo
  • BME280 GND todo
Source code
Common
Packet format
  • PM10 value, encoded in units of 0.1 ug/m3: 2 bytes, big endian
  • PM2.5 value, encoded in units of 0.1 ug/m3: 2 bytes, big endian
  • temperature, encoded in units of 0.1 deg C: 2 bytes, signed big endian
  • relative humidity, encoded in units of 0.1%, 2 bytes, big endian
Total: 8 bytes
A smaller payload means less time in the air, smaller chance of collision with other LoRa packets and more packets per hour.
Node
platformio
 sudo apt-get install python-pip
 sudo pip install platformio
 pio update
To compile and upload:
design
  • The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
  • The App EUI is generated in the TTN console, it is the same for all nodes
  • The App Key is generated in the TTN console, it is the same for all nodes
  • The device is registered in the TTN console by the Device EUI (this doesn't happen automatically). Frame counter checks are disabled.
  • OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
  • OTAA progress is shown on the OLED
  • If OTAA has been done successfully, the node restores the session parameters negotiated during OTAA on next bootup, so it can quickly resume sending data.
  • I'm NOT saving the upload frame counter (this would be preferable), just disable the feature in the TTN console.
TODO to figure out:
  • What about the channel setup? The node connects using 3 frequencies, but receives a bigger list of frequencies during OTAA JOIN.
 40829907: engineUpdate, opmode=0x8
 40829935: EV_TXSTART
 40829939: engineUpdate, opmode=0x888
 40830013: TXMODE, freq=868300000, len=25, SF=11, BW=125, CR=4/5, IH=0
 40944876: setupRx1 txrxFlags 0x22 --> 01
 start single rx: now-rxtime: 5
 40945013: RXMODE_SINGLE, freq=868300000, SF=11, BW=125, CR=4/5, IH=0
 rxtimeout: entry: 40951170 rxtime: 40945001 entry-rxtime: 6169 now-entry: 5 rxtime-txend: 63524
 41005584: setupRx2 txrxFlags 0x1 --> 02
 start single rx: now-rxtime: 4
 41005720: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
 41017003: process options (olen=0x5)
 41017012: LinkAdrReq: p1:11 chmap:00ff chpage:00 uprt:01 ans:86
 41017019: ??ack error ack=1 txCnt=0
 41017073: decodeFrame txrxFlags 0x2 --> 22
 41017312: Received downlink, window=RX2, port=-1, ack=1, txrxFlags=0x22
 41017708: EV_TXCOMPLETE (includes waiting for RX windows)
 41018027: engineUpdate, opmode=0x800
Backend
Example upstream data:
Example downstream data:
