LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2019-04-24
The idea
  • a forwarde application that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but I can't figure out the 'best' solution:
  • source code location is obscure, I will publish all source code on github and put up documentation on this wiki
  • everyone invents their own payload format, I'd like to use something relatively universal and standard, so I think I will try to use the Cayenne LPP format.
Sensors join the network using OTAA (instead of ABP), that way I try to minimize the setup of each individual node. All nodes use the same application EUI and the same application key.
So I'd like to just re-invent the wheel properly this time.
  • Investigate failing re-joins that seem to happen some time after the node has been online
  • Implement a kind of schedule: turn the sds011 on, wait some time, take a measurement, turn it off, wait for some time
    • make this match the TTN send schedule? it's useless to do a measurement if we don't have TTN airtime to transmit it
  • Finish the Java software (MQTT listener, payload decoder, luftdaten forwarder)
    • I don't know what kind of id I can use towards Luftdaten, the regular convention is "esp8266-XXXX", where XXXX is the unique ESP id.
Dump
The node is based on Arduino, in particular a TTGO ESP32 board with onboard LoRa chip. The sensor is an SDS-011, just like in the luftdaten project.
NOTE: https://www.thethingsnetwork.org/community/berlin/post/warning-attention-users-of-ttgo21-v16-boards-labeled-t3_v16-on-pcb-battery-exploded-and-got-on-fire
  • SDS011 5V to ESP32 5V
  • SDS011 GND to ESP32 GND
  • SDS011 TXD to ESP32 GPIO35 (maybe I can find two suitable pins close together)
  • SDS011 RXD to ESP32 GPIO25 (maybe I can find two suitable pins close together)
  • BME280 3V todo
  • BME280 SDA todo
  • BME280 SCL todo
  • BME280 GND todo
Source code
Common
Packet format
  • PM10 value, encoded in units of 0.1 ug/m3: 2 bytes, big endian
  • PM2.5 value, encoded in units of 0.1 ug/m3: 2 bytes, big endian
  • temperature, encoded in units of 0.1 deg C: 2 bytes, signed big endian
  • relative humidity, encoded in units of 0.1%, 2 bytes, big endian
Total: 8 bytes
Node
platformio
 sudo apt-get install python-pip
 sudo pip install platformio
 pio update
To compile and upload:
design
  • The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
  • The App EUI is generated in the TTN console, it is the same for all nodes
  • The App Key is generated in the TTN console, it is the same for all nodes
  • The device is registered in the TTN console by the Device EUI (this doesn't happen automatically). Frame counter checks are disabled.
  • OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
    • Perhaps with a long press on the button, we can reset the OTAA?
  • OTAA progress is shown on the OLED
  • If OTAA has been done successfully, the node restores the session parameters negotiated during OTAA on next bootup, so it can quickly resume sending data.
  • I'm NOT saving the upload frame counter (this would be preferable), just disable the feature in the TTN console.
TODO to figure out:
  • What about the channel setup? The node connects using 3 frequencies, but receives a bigger list of frequencies during OTAA JOIN.
 40829907: engineUpdate, opmode=0x8
 40829935: EV_TXSTART
 40829939: engineUpdate, opmode=0x888
 40830013: TXMODE, freq=868300000, len=25, SF=11, BW=125, CR=4/5, IH=0
 40944876: setupRx1 txrxFlags 0x22 --> 01
 start single rx: now-rxtime: 5
 40945013: RXMODE_SINGLE, freq=868300000, SF=11, BW=125, CR=4/5, IH=0
 rxtimeout: entry: 40951170 rxtime: 40945001 entry-rxtime: 6169 now-entry: 5 rxtime-txend: 63524
 41005584: setupRx2 txrxFlags 0x1 --> 02
 start single rx: now-rxtime: 4
 41005720: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
 41017003: process options (olen=0x5)
 41017012: LinkAdrReq: p1:11 chmap:00ff chpage:00 uprt:01 ans:86
 41017019: ??ack error ack=1 txCnt=0
 41017073: decodeFrame txrxFlags 0x2 --> 22
 41017312: Received downlink, window=RX2, port=-1, ack=1, txrxFlags=0x22
 41017708: EV_TXCOMPLETE (includes waiting for RX windows)
 41018027: engineUpdate, opmode=0x800
Backend
I've already developed some Java code that publishes the measurement values towards luftdaten.info. Also I've developed code before to subscribe to the TTN MQTT stream.
Example upstream data:
Example downstream data:
