LoraWanDustSensor
| Last Update | 2019-04-18 |
The plan
The plan is to create a system consisting of:
- a sensor that measures airborne particulate matter and sends the measurement data using LoRa/TheThingsNetwork to a central location.
- a backend that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but I can't figure out the 'best' solution:
- source code location is obscure, I will publish all source code on github and put up documentation on this wiki
- everyone invents their own payload format, I'd like to use something relatively universal and standard, so I think I will try to use the Cayenne LPP format.
Sensors join the network using OTAA (instead of ABP), that way I try to minimize the setup of each individual node. All nodes use the same application EUI and the same application key.
So I'd like to just re-invent the wheel properly this time.
- Investigate failing re-joins that seem to happen some time after the node has been online
- Implement a kind of schedule: turn the sds011 on, wait some time, take a measurement, turn it off, wait for some time
- make this match the TTN send schedule? it's useless to do a measurement if we don't have TTN airtime to transmit it
- Finish the Java software (MQTT listener, payload decoder, luftdaten forwarder)
Dump
The node is based on Arduino, in particular a TTGO ESP32 board with onboard LoRa chip. The sensor is an SDS-011, just like in the luftdaten project.
- SDS011 5V to ESP32 5V
- SDS011 GND to ESP32 GND
- SDS011 TXD to ESP32 GPIO25 (maybe I can find two suitable pins close together)
- SDS011 RXD to ESP32 GPIO34 (maybe I can find two suitable pins close together)
- BME280 3V todo
- BME280 SDA todo
- BME280 SCL todo
- BME280 GND todo
Common
Packet format
- structure version id: 2 bytes
- PM10 value, encoded in units of 0.1 ug/m3: 2 bytes
- PM2.5 value, encoded in units of 0.1 ug/m3: 2 bytes
- temperature, encoded in units of 0.1 deg C: 2 bytes
- relative humidity, encoded in units of 0.1%, 2 bytes
Total: 10 bytes
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- 2 bytes: P10 (?) big endian (unit 0.01 ug/m3)
- 2 bytes: P25 (?) big endian (unit 0.01 ug/m3)
- 2 bytes: humidity (unit of 0.01% ?)
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
Node
platformio
sudo apt-get install python-pip sudo pip install platformio pio update
To compile and upload:
design
- The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
- The App EUI is generated in the TTN console, it is the same for all nodes
- The App Key is generated in the TTN console, it is the same for all nodes
- The device is registered in the TTN console by the Device EUI (this doesn't happen automatically). Frame counter checks are disabled.
- OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
- Perhaps with a long press on the button, we can reset the OTAA?
- OTAA progress is shown on the OLED
- If OTAA has been done successfully, the node restores the session parameters negotiated during OTAA on next bootup, so it can quickly resume sending data.
- I'm NOT saving the upload frame counter (this would be preferable), just disable the feature in the TTN console.
TODO to figure out:
- What about the channel setup? The node connects using 3 frequencies, but receives a bigger list of frequencies during OTAA JOIN.
40829907: engineUpdate, opmode=0x8 40829935: EV_TXSTART 40829939: engineUpdate, opmode=0x888 40830013: TXMODE, freq=868300000, len=25, SF=11, BW=125, CR=4/5, IH=0 40944876: setupRx1 txrxFlags 0x22 --> 01 start single rx: now-rxtime: 5 40945013: RXMODE_SINGLE, freq=868300000, SF=11, BW=125, CR=4/5, IH=0 rxtimeout: entry: 40951170 rxtime: 40945001 entry-rxtime: 6169 now-entry: 5 rxtime-txend: 63524 41005584: setupRx2 txrxFlags 0x1 --> 02 start single rx: now-rxtime: 4 41005720: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0 41017003: process options (olen=0x5) 41017012: LinkAdrReq: p1:11 chmap:00ff chpage:00 uprt:01 ans:86 41017019: ??ack error ack=1 txCnt=0 41017073: decodeFrame txrxFlags 0x2 --> 22 41017312: Received downlink, window=RX2, port=-1, ack=1, txrxFlags=0x22 41017708: EV_TXCOMPLETE (includes waiting for RX windows) 41018027: engineUpdate, opmode=0x800
Backend
I've already developed some Java code that publishes the measurement values towards luftdaten.info. Also I've developed code before to subscribe to the TTN MQTT stream.
Example upstream data:
Example downstream data:
