LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2019-04-13
The plan
The plan is to create a system consisting of:
  • a sensor that measures airborne particulate matter and sends the measurement data using LoRa/TheThingsNetwork to a central location.
  • a backend that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but can't find any really good examples:
  • source code location is obscure, I will publish all source code on github and put up documentation on this wiki
  • payload format is non-standard, I'd like to use something relatively universal and standard, so I think I will try to use the Cayenne LPP format.
Sensors join the network using OTAA (instead of ABP), that way I try to minimize the setup of each individual node.
So I'd like to just re-invent the wheel properly this time.
  • Make it work with the 'old' LMIC library and ABP
  • Try out the 'new' LMIC library at https://github.com/mcci-catena/arduino-lmic
  • Experiment with OTAA, saving OTAA parameters, restoring OTAA parameters, see
  • Finish the Java software (MQTT listener, payload decoder, luftdaten forwarder)
Dump
The node is based on Arduino, in particular a TTGO ESP32 board with onboard LoRa chip. The sensor is an SDS-011, just like in the luftdaten project.
NOTE: https://www.thethingsnetwork.org/community/berlin/post/warning-attention-users-of-ttgo21-v16-boards-labeled-t3_v16-on-pcb-battery-exploded-and-got-on-fire
  • SDS011 5V to ESP32 5V
  • SDS011 GND to ESP32 GND
  • SDS011 TXD to ESP32 GPIO25
  • SDS011 RXD to ESP32 GPIO34
Source code can be found on the github page.
Common
Packet format
Packets transferred over LoRa contain:
  • structure version id: 2 bytes
  • PM10 value, encoded in units of 0.1 ug/m3: 2 bytes
  • PM2.5 value, encoded in units of 0.1 ug/m3: 2 bytes
  • temperature, encoded in units of 0.1 deg C: 2 bytes
  • relative humidity, encoded in units of 0.1%, 2 bytes
Total: 10 bytes
Node
To compile the code, platformio is used, see the github archive.
For OTAA, I use the following scheme, to keep administration to a minimum:
  • The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
  • The App EUI is generated in the TTN console, it is the same for all nodes
  • The App Key is generated in the TTN console, it is the same for all nodes
  • The device is registered in the TTN console by the Device EUI (if this doesn't happen automatically)
  • OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
    • Perhaps with a long press on the button, we can reset the OTAA?
  • OTAA progress is shown on the OLED
  • If OTAA has been done successfully, the node restores the session parameters on next bootup
  • I'm NOT saving the upload frame counter (this would be preferable), just disable the feature in the TTN console.
For OTAA, the following needs to be saved/restored:
  • LMIC.nwkKey (16 bytes)
  • LMIC.artKey (16 bytes)
  • LMIC.seqnoUp (32-bit number)
  • LMIC.devaddr (4 bytes)
Logic:
  • To start an OTAA join from scratch, use LMIC_startJoining();
  • To continue from previous OTAA
    • use LMIC_setSession() with parameters retrieved from LMIC_getSessionKeys() just after OTAA join;
    • LMIC.seqnoUp = savdata.seqnoUp;
  • What about the channel setup? The node connects using 3 frequencies, but receives a bigger list of frequencies during OTAA JOIN.
 40829907: engineUpdate, opmode=0x8
 40829935: EV_TXSTART
 40829939: engineUpdate, opmode=0x888
 40830013: TXMODE, freq=868300000, len=25, SF=11, BW=125, CR=4/5, IH=0
 40944876: setupRx1 txrxFlags 0x22 --> 01
 start single rx: now-rxtime: 5
 40945013: RXMODE_SINGLE, freq=868300000, SF=11, BW=125, CR=4/5, IH=0
 rxtimeout: entry: 40951170 rxtime: 40945001 entry-rxtime: 6169 now-entry: 5 rxtime-txend: 63524
 41005584: setupRx2 txrxFlags 0x1 --> 02
 start single rx: now-rxtime: 4
 41005720: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
 41017003: process options (olen=0x5)
 41017012: LinkAdrReq: p1:11 chmap:00ff chpage:00 uprt:01 ans:86
 41017019: ??ack error ack=1 txCnt=0
 41017073: decodeFrame txrxFlags 0x2 --> 22
 41017312: Received downlink, window=RX2, port=-1, ack=1, txrxFlags=0x22
 41017708: EV_TXCOMPLETE (includes waiting for RX windows)
 41018027: engineUpdate, opmode=0x800
Backend
I've already developed some Java code that publishes the measurement values towards luftdaten.info. Also I've developed code before to subscribe to the TTN MQTT stream.
Example upstream data:
Example downstream data:
