LoraWanDustSensor
| Last Update | 2019-04-11 |
The plan
The plan is to create a system consisting of:
- a sensor that measures airborne particulate matter and sends the measurement data using LoRa/TheThingsNetwork to a central location.
- a backend that collects the data from TTN and forwards it to luftdaten.info
This has been done before by other people, but can't find any really good examples:
- source code location is obscure, I will publish all source code on github and put up documentation on this wiki
- payload format is non-standard, I'd like to use something relatively universal and standard, so I think I will try to use the Cayenne LPP format.
Sensors join the network using OTAA (instead of ABP), that way I try to minimize the setup of each individual node.
So I'd like to just re-invent the wheel properly this time.
- Make it work with the 'old' LMIC library and ABP
- Try out the 'new' LMIC library at https://github.com/mcci-catena/arduino-lmic
- Experiment with OTAA, saving OTAA parameters, restoring OTAA parameters, see
- Finish the Java software (MQTT listener, payload decoder, luftdaten forwarder)
Dump
The node is based on Arduino, in particular a TTGO ESP32 board with onboard LoRa chip. The sensor is an SDS-011, just like in the luftdaten project.
- SDS011 5V to ESP32 5V
- SDS011 GND to ESP32 GND
- SDS011 TXD to ESP32 GPIO25
- SDS011 RXD to ESP32 GPIO34
Source code can be found on the github page.
Common
Packet format
Packets transferred over LoRa contain:
- structure version id: 2 bytes
- PM10 value, encoded in units of 0.1 ug/m3: 2 bytes
- PM2.5 value, encoded in units of 0.1 ug/m3: 2 bytes
- temperature, encoded in units of 0.1 deg C: 2 bytes
- relative humidity, encoded in units of 0.1%, 2 bytes
Total: 10 bytes
Node
To compile the code, platformio is used, see the github archive.
For OTAA, I plan to use the following scheme, to keep administration to a minimum:
- The Device EUI is derived from the ESP32 MAC address, the node shows this on its OLED
- The App EUI is generated in the TTN console, it is the same for all nodes
- The App Key is generated in the TTN console, it is the same for all nodes
- The device is registered in the TTN console by the Device EUI (if this doesn't happen automatically)
- OTAA is done only once for each node. After that, the OTAA parameters are stored in (simulated) EEPROM.
- Perhaps with a long press on the button, we can reset the OTAA?
- OTAA progress is shown on the OLED
- If OTAA has been done successfully, the node uses a kind of ABP mode using the parameters established with OTAA
- not sure if we also save/restore the frame counter (this would be preferable), or just disable the feature in the TTN console.
For OTAA, the following needs to be saved/restored:
- LMIC.nwkKey (16 bytes)
- LMIC.artKey (16 bytes)
- LMIC.seqnoUp (32-bit number)
- LMIC.devaddr (4 bytes)
Logic:
- To start an OTAA join from scratch, use LMIC_startJoining();
- To continue from previous OTAA
- use LMIC_setSession() with parameters retrieved from LMIC_getSessionKeys() just after OTAA join;
- LMIC.seqnoUp = savdata.seqnoUp;
Backend
I've already developed some Java code that publishes the measurement values towards luftdaten.info. Also I've developed code before to subscribe to the TTN MQTT stream.
