STM32
| Project STM32 | |
| STM32 setup guide | |
| Last Update | 2019-02-24 |
This page is about inexpensive microcontroller boards containing an STM32 processor and how to get them to work.
You can find these boards on AliExpress for less than €2,- if you search for "stm32f103c8t6". Yet they have nice specifications, see also http://www.st.com/en/microcontrollers/stm32f103c8.html
To name a few:
- 32-bit ARM Cortex-M3 processor running at up to 72 MHz
- 128 kB flash memory, 20 kB SRAM
- USB and CAN controllers
- 32 kHz crystal for RTC
- dual 1 us A/D converter, DMA controller
- the usual stuff like SPI, UART, I2C
They are even Arduino compatible, see:
- Arduino for STM32
- Arduino goes STM32, a quick tutorial
- Arduino STM32 page of Roger Clark
Another, very similar, guide to getting started with STM32 and Arduino.
Although it is possible to program the board over the serial port for every iteration of your application, I recommend to install the STM32duino bootloader. This way, you only need to wire up a USB/serial conversion board and set/reset jumpers only once for bootloader installation and from that point on you can program the board over USB.
Setting up the tool chain
This describes the steps I did to get a "blue pill" board to work on Debian Jessie.
Linux specific
Some things I suspect may make things more smooth:
- uninstall the 'modemmanager' package, it suspect it interferes with the serial port device created by the STM32duino bootloader
sudo apt-get autoremove modemmanager
Arduino IDE
Steps to set up the IDE:
- get and install the latest Arduino IDE from here.
- under menu Tools / Board / Board Manager, search for "zero" and install the Arduino Zero toolchain
- get the Arduino_STM32 source code, for example, run in the console:
cd ~/code mkdir stm32 cd stm32 git clone https://github.com/rogerclarkmelbourne/Arduino_STM32
- create a symlink to the Arduino_STM32 source tree in your ~/Arduino/hardware directory, for example:
cd ~/Arduino/hardware ln -s ~/code/stm32/Arduino_STM32 .
- restart the Arduino IDE.
Platform IO
Below is an example platformio configuration for a blue pill with the USB bootloader. Save this to a file named platformio.ini in the directory where the .ino file is, and run it with 'pio run'.
[platformio] src_dir = . [env:bluepill_f103c8] platform = ststm32 board = bluepill_f103c8 framework = arduino upload_protocol = dfu
stm32flash
If you're running a 64-bit Linux, it can be convenient to add support for the 32-bit stm32flash utility, run:
sudo apt-get install libc6-i386
The tool chain installation should now be ready.
The hardware I'm using, is the blue pill, I soldered on the headers for easy plugging with dupont-wire.
Flashing the USB bootloader
The USB bootloader makes it easy/fast to upload new software into the board.
You need a USB-serial converter for this.
Wire it up as follows:
- converter 5V -> board 5V
- converter GND -> board GND
- converter RXD -> board A9
- converter TXD -> board A10
Set the BOOT0 jumper to the "1" position and the BOOT1 jumper to the "0" position, then push the reset button.
For the blue pill the steps to install the bootloader are as follows:
- cd into the directory Arduino_STM32/tools/linux/stm32flash
- flash the bootloader:
./stm32flash -w ~/code/stm32/STM32duino-bootloader/binaries/generic_boot20_pc13.bin -v -g 0x0 /dev/ttyUSB0
- return both BOOT jumpers to the "0" position.
To load your application using the Arduino IDE:
- in the Arduino IDE, under menu Tools / Board, select "Generic STM32F103C Series"
- in the Arduino IDE, under menu Tools / Upload Method, select "STM32duino bootloader"
- use the following program to blink the on-board LED:
#define pinLED PC13
void setup() {
pinMode(pinLED, OUTPUT);
void loop() {
digitalWrite(pinLED, HIGH);
delay(200);
digitalWrite(pinLED, LOW);
delay(100);
- ctrl-U to upload it to the board, the program will start automatically
Unlocking/erasing the first time (old information)
You might find that the flash is protected on a new board, this means you cannot put your own program on the board. You can fix this as follows:
- go the stm32flash directory
cd ~/Arduino/hardware/Arduino_STM32/tools/linux/stm32flash
- use the stm32flash utility to disable the flash-read protection
./stm32flash /dev/ttyUSB0 -k
Future work
Actually build something with an STM32!
Ideas:
- a LoRaWAN node for The-Things-Network
- a bat call recorder, this thing is faster and has more memory than the LPC2148 in my previous bat call recorder prototype
Investigate the Blackmagic debugging firmware. This should allow you to debug your applications (e.g. step through code in an IDE such as eclipse). See also:
