Stofradar
Project Stofradar | |
Visualizing atmospheric particulate matter concentrations on a map | |
Contact | bertrik |
Last Update | 2019-02-28 |
This page is about creating a 'stofradar' image of atmospheric particulate matter concentrations based on the raw data measured by the luftdaten.info network, see www.stofradar.nl.
See also my DustSensor page.
The website luftdaten.info is an initiative to allow citizens to participate in measuring atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is > 6000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has about 100 sensors.
Future activities:
- plot PM2.5 and apply humidity correction
- retrieve official luchtmeetnet measurements and plot them on the map too, more information on their API: https://api-docs.luchtmeetnet.nl/ and my work in progress at https://github.com/bertrik/luftdatenmapper/tree/master/workspace/luftdatenmapper/src/main/java/nl/bertriksikken/luchtmeetnet/api
- use an OSM background map
- improve fine alignment between map and dust overlay
- create a map of a larger area, including germany (it has a lot of data points)
- review and update stats mentioned above (e.g. "100 sensors in netherlands")
- verify that gzip compression is used on the luftdaten JSON download
Visualisation
Background map
Pages to investigate:
- https://wiki.openstreetmap.org/wiki/OSM_on_Paper
- http://maps.stamen.com/m2i/#toner-background/600:800/6/52.200/5.300
- https://developer.mapquest.com/documentation/open/static-map-api/v5/examples/basic/map-bounding-box/
What I need/want is to be able to specify the 'bounding box' and use a equirectangular projection , so I can easily map a pixel back to a latitude/longitude.
Interpolation
- calculate the "middle" of the map (average latitude/longitude between top-left and bottom-right);
- calculate the "km-per-degree-latitude" at the middle for latitude as 40000 km / 360 degrees;
- calculate the "km-per-degree-longitude" at the middle for longitude as the number above multiplied with cos(latitude);
- determine the difference in longitude and the difference in latitude;
- convert both to km using the factors calculated earlier;
- calculate the euclidean distance.
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
Pixels that are not within a certain distance of any sensor station (e.g. 25 km) are rendered as grayscale, to indicate a geographic limit of each sensor.
Only sensors within a reasonable range of the map are taken into account, currently this is an area of 9 times (3x3) the visible area.
PM10 values higher than 500 ug/m3 are simply ignored in the software.
Colour range
The colours I'm using (a kind of inverted spectral range from blue to red):
- 0 ug/m3: fully transparent white (#FFFFFF)
- 25 ug/m3: semi-transparent cyan (#00FFFF)
- 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average for PM10 in the Netherlands.
- 100 ug/m3: semi-transparent red (#FF0000)
- 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Correction for high humidity
Humidity generally seems to cause an overestimation of PM measurements for measurements done with a "particle counting" type of PM sensor. The effect become really significant above approximately 70% humidity.
An interesting idea is to try to compensate for this effect, since the luftdaten sensor has an onboard humidity-sensor. Some papers/links about this:
- https://www.samenmetenaanluchtkwaliteit.nl/sites/default/files/2018-07/Status_SDS011_12juli18.pdf
- https://www.researchgate.net/publication/320474792_Influence_of_Humidity_on_the_Accuracy_of_Low-Cost_Particulate_Matter_Sensors
- https://github.com/opendata-stuttgart/meta/wiki/Luftfeuchte-Korrektur
- it combines formulas and coefficients from different sources where relative humidity has different units. One paper seems to use an RH-value from 0 to 100, while another uses a kind of normalized relative humidity (from 0 to 1). You cannot just use the same coefficients if the unit is different.
- it claims a humidity correction for PM10 with coefficients that is not found in the source paper.
Compositing
I use imagemagick for this, for example:
composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
Animation
The idea of animation is to combine several 5-minute images into a movie.
There are several options and file formats to choose from:
- GIF appears way too big, resulting in files of about 40 MB for 288 frames.
- APNG is only slighty smaller at about 37 MB.
- the webm format seems more suited, can be less than 1MB (lossy, VP9).
Example conversion command for webm:
cat ~/luftdatenmapper/tmp/netherlands/*.png |ffmpeg -f image2pipe -r 12 -i - -b:v 200k netherlands.webm
This results in an output file of about 650 kB.
