Stofradar
Project Stofradar | |
Visualizing fine dust concentrations on a map | |
Contact | bertrik |
Last Update | 2018-06-13 |
This page is about creating a 'stofradar' image of fine dust concentrations based on the raw data measured by the luftdaten.info network, see www.stofradar.nl.
See also my DustSensor page.
luftdaten.info is an initiative to allow citizens to measure fine dust concentration using an inexpensive and easy to build fine dust sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is about 5000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has about 100 sensors.
Future activities:
- add a timestamp to the image
- put all of the images from one day into an animation
- massage the data a bit, e.g. remove sensors that are known to give anomalous readings, etc.
Visualisation
The general idea is to create an image, with a map at the background and the fine dust concentration overlaid on top.
TODO:
- get a nice background map, I prefer the equirectangular projection since that is easy to calculate. A black-and-white map would be nice so the overlay adds all the colour.
- find a way to combine images over time into an animated gif: imagemagick convert?
Background map
Pages to investigate:
- https://wiki.openstreetmap.org/wiki/OSM_on_Paper
- http://maps.stamen.com/m2i/#toner-background/600:800/6/52.200/5.300
Interpolation
To calculate the distance2, I use a very simple approximation:
- determine the difference in longitude and latitude
- apply an 'aspect ratio' factor of cos(latitude) to the longitude difference. I use the latitude of the approximate middle of the netherlands (52.2 lat, 5.3 lon) to calculate this aspect ratio factor.
- distance2 = (difference latitude)2 + (difference longitude)2
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
Colour range
The colours I'll probably be using (a kind of spectral range from blue to red):
- 0 ug/m3: fully transparent white (#FFFFFF)
- 25 ug/m3: semi-transparent cyan (#00FFFF)
- 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average in the Netherlands.
- 100 ug/m3: semi-transparent red (#FF0000)
- 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
Values in between these levels are interpolated with respect to the RGB colour value and alpha channel.
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Compositing
I plan to use imagemagick for this.
Work in progress:
composite -compose over -geometry 800x600 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
