| Project Radio controlled Bicycle back light | |
| A battery powered bicycle back light that can be used to find your bike. | |
| Status | Initializing |
| Contact | Mahjongg |
| Last Update | 2018-03-06 |
I engineered a solution around a 315MHz receiver.
This is the (updated to rev 2.1) schematic.
Bestand:RF Achterlicht rev2.1.pdf
Also updated the schematic: Bestand:Rf achterlicht rev 2,2.pdf this is the component placement drawing as a .PDF : Bestand:Componenten opstelling rf backlight rev 2,2.pdf
this is a 3D rendering of the PCB with the latest component placement, and now also layout.
Here are pictures of the PCB, left topside, right bottom side. Now with silk screen printing
6 March, 2018, calculated LC resonance values
Calculated the values for the L and C of the 315MHz resonance circuit with f= 1/(2 * PI * SQR(L*C)) . Using a trim-cap trimable between 3 and 10pf, we estimate the average capacity at 6.5pf, meaning the inductance should be about 39nH (see resonance calculator here: http://www.1728.org/resfreq.htm ). I now found a suitable 39nH coil, (Coilcraft 1812SMS-39N_L_) so I can add a footprint for it. I will also add footprints for a 0603 cap, so I can replace the trim-cap with a fixed one if I want to use a trimable coil instead of a trimable cap.
