Project Radio controlled Bicycle back light
A battery powered bicycle back light that can be used to find your bike.
Status Initializing
Contact Mahjongg
Last Update 2018-02-14
I engineered a solution around a 315MHz receiver. This is the (updated to rev 2.1) schematic. Bestand:RF Achterlicht rev2.1.pdf
Also updated the schematic: Bestand:Rf achterlicht rev 2,2.pdf this is the component placement drawing as a .PDF : Bestand:Componenten opstelling rf backlight rev 2,2.pdf
this is a 3D rendering of the PCB with the latest component placement, and now also layout.
Here are pictures of the PCB, left topside, right bottom side, this version doesn't have silk screen printing yet:
