Project Radio controlled Bicycle back light | |
A battery powered bicycle back light that can be used to find your bike. | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2018-02-14 |
I engineered a solution around a 315MHz receiver. This is the (updated to rev 2.1) schematic. File:RF Achterlicht rev2.1.pdf
Also updated the schematic: File:Rf achterlicht rev 2,2.pdf this is the component placement drawing as a .PDF : File:Componenten opstelling rf backlight rev 2,2.pdf
this is a 3D rendering of the PCB with the latest component placement, and now also layout.
Here are pictures of the PCB:
