Luteijn/IRRemotes
Project "IRRemotes":
| Project Luteijn/IRRemotes | |
| File:I.R. Baboon 301-1-.png | |
| Contact | Luteijn |
| Last Update | 2018-02-03 |
IRRemotes
Controlling things with an IR Remote is fun. Here's what some of my remotes send out, for easy (re)use in projects with an IR Receiver. Sniffed the codes with a Vortex robot, made up the names in the tables myself.
RC6 'windows' remote
This sends 36-bit RC6 codes. They all seem to be of the form 0xC8034x4hl. The leading C doesn't show with my current decoder of choice, or isn't really there. The x is either 8 or 0, flipping for each key pressed, so you can distinguish between a key being held or pushed twice in a row. The h and l indicate the variable bits in the code sent, the table below gives a name to each of these. Order is a left to right, top to bottom scan of the remote, treating the volume and channel + - as one, rocker, button.
| Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | Code | Label | |||||
| 0C | power | 30 | pause | 37 | record | 31 | stop | 29 | reverse | 2C | play | |||||
| 28 | forwards | 21 | previous | 20 | next | 83 | back | CB | info | 58 | up | |||||
| 5A | left | 5C | ok | 5B | right | 59 | down | 10 | vol+ | 11 | vol- | |||||
| 5D | logo | 1E | ch+ | 1F | ch- | 0D | mute | 9B | tvrecord | 3E | tvguide | |||||
| 2E | tvplay | 54 | disc | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | |||||
| 05 | 5 | 06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 33 | * | |||||
| 00 | 0 | 32 | # | 3A | clear | 2F | teletext | 34 | enter | 6D | red | |||||
| 6E | green | 6F | yellow | 70 | blue |
Sorted by code:
| 00 | 0 | 01 | 1 | 02 | 2 | 03 | 3 | 04 | 4 | 05 | 5 | |||||
| 06 | 6 | 07 | 7 | 08 | 8 | 09 | 9 | 0C | power | 0D | mute | |||||
| 10 | vol+ | 11 | vol- | 1E | ch+ | 1F | ch- | 20 | next | 21 | previous | |||||
| 28 | forwards | 29 | reverse | 2C | play | 2E | tvplay | 2F | teletext | 30 | pause | |||||
| 31 | stop | 32 | # | 33 | * | 34 | enter | 37 | record | 3A | clear | |||||
| 3E | tvguide | 54 | disc | 58 | up | 59 | down | 5A | left | 5B | right | |||||
| 5C | ok | 5D | logo | 6D | red | 6E | green | 6F | yellow | 70 | blue | |||||
| 83 | back | 9B | tvrecord | CB | info |
RTeL-Cheapo remote
This El-Cheapo remote came with one of my RTL-dongles. Decodes as an NEC-code, sending a 32-bit code when a key is pressed, followed by a 0-bit code as long as the key is held.
| Code | Label |
| FFB24D | Power |
