Spectrum polish off
Versie door Mahjongg (overleg | bijdragen) op 16 jan 2016 om 21:05 (Updated project data)
Project Spectrum polish off
repairing a Sinclair Spectrum and providing it with a new (real) keyboard, a Joystick port, composite video input, and a much more sensitive microphone input.
Contact mahjongg
Last Update 2016-01-16
Sinclair Spectrum polish off is a project to restore a donated defective Sinclair spectrum to working order, and to add some additional features:
All Fixes are done, including:
  • Replaced blown up 7805 voltage regulator.
  • Repaired the +12V & -5V generator (replaced two transistors).
  • Completely replaced foil keyboard by 40 6x6mm buttons, hot glued to the inside and hard wired, the rubber keypad was modified to make place for the buttons.
  • Built in a 1 transistor preamp to make the cassette input sensitive enough so it accepts signals from a tablet or laptop.
  • replaced a missing rubber feet
  • added a composite video output cable
  • Add a built in joystick port, that works by activating certain keys, by using FET's connected between the keyboard matrix points for the keys, 5,6,7 & 8, and 0 for fire.
The latter was also a test case for an identical solution in my ZX14 (ZX81 rebuild). It works, but only when using the right kind of FET's, the first FET's I tried (BS170's) did not work! Probably because of it's largish (200pF) drain-source and gate source capacitances, but using 2N7000 FET's did work. In the ZX14 I will be using the 2N7002, which is a 2N7000 in a SOT-23 SMT package instead of the 2N7000's TO-92 PTH package.
A less positive note is that even with the transistor pre-amp the cassette input is still quite finicky and still not sensitive enough and needs a lot of signal to work properly.
Spectrum keyboard with real keys and joystick interface
Note that this spectrum, (and the CPC646 mentioned here) and about a hundred other systems in my possession, were donated to awesome space on good Friday (April 3) 2015 to awesome space http://awesomespace.nl.
