3d-printer-compare
3D printer vergelijking
Besproken op de metameet van 13x05x2014. Eerste model (Mankati) is via Rix, tweede model (Carteso) zit in maasstricht en Lulzbot onbekend.
Mankati Fullscale XT Cartesio W1CE Lulzbot TAZ 4 Ultimaker II
Price 2150 3600 2195 € 2300 incl. BTW
PLA YES x YES YES
ABS YES x YES YES
PVA YES x YES ?
Filament Diameter 3 mm 3 mm 3 mm 2.85 mm
Filament Temp 150 tot 250 °C x max 240 °C 180 - 260 °C
File support stl, obj, gcode x STL / OBJ / DAE / AMF
Print speed -180 mm/s -150 mm/s -200 mm/s 30-300 mm/s
Accuracy* X,Y axis 0.0125 mm, Z axis 0.001 mm 0,28 mm 0,1 mm 0.0125 mm (X,Y), 0.005 mm (Z)
Stepper Motor* X, Y 4248, 1.3A, Z 4263, 1.5A x x x
Controller* Arduino Mega 2560 R3 x open source YES
Linux YES x YES YES
Software MankatiUM (Based on Cura) x x Cura
Extruders max 2 max 4 max 1
Max. print dimensions 250×250×300 mm 400x200x200 mm 297x274x248 mm 230x225x205 mm
Extrude Nozzle 0,4 mm (0,3 en 0,5 beschikbaar) x 0.075mm to 0.35mm 0.4 mm
Hot bed YES x YES 50-100 °C
Bed materiaal Monocrystal glass x Borosilicate glass bed covered with PET film glass
Closed printing area Ja Ja Nee closed sides, open front/top
External dimensions 380x420x530 mm x 680x520x515 mm 492x342x558 mm (incl. filament)
Weight* 25kg x 11kg YES
Notes x Graveert ook Open source hardware & software, print ook nylon, Laywood, Laybrick & Ninjaflex
Link http://www.mankati.com/fullscale-xt.html http://mauk.cc/webshop/systems/cartesio-assembled/Cartesio-w1ce-assembled https://www.lulzbot.com/products/lulzbot-taz-4-3d-printer https://www.ultimaker.com/pages/our-printers/ultimaker-2
x = niet bekend
  • = unreliable or irrelevant specification
