ImprovedLaosLaser
Project Improved LaosLAser | |
Contact | FooBar |
Last Update | 2014-01-08 |
Thanks to Stoneshop @ #42 there is an improved LaosLaser board design available:
- http://rsteenw.home.xs4all.nl/misc/laos_rs.brd
- http://rsteenw.home.xs4all.nl/misc/laos_rs.sch
- https://hack42.nl/mediawiki/images/d/d0/Eagle_laos_v1.zip
Schematic
Board
BOM
Part | Value | Device | Package | Description |
C1 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C2 | 100u 25V | CPOL-EUE5-8.5 | E5-8,5 | POLARIZED CAPACITOR |
C3 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C4 | 1000u 25V | CPOL-EUE5-13 | E5-13 | POLARIZED CAPACITOR |
C5 | 100n | C-EU050-025X075 | C050-025X075 | CAPACITOR |
C6 | 100u 25V | CPOL-EUE5-10.5 | E5-10,5 | POLARIZED CAPACITOR |
C7 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C8 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C9 | 100u 25V | CPOL-EUE5-8.5 | E5-8,5 | POLARIZED CAPACITOR |
C10 | 100u 25V | CPOL-EUE5-8.5 | E5-8,5 | POLARIZED CAPACITOR |
C11 | 100u 25V | CPOL-EUE5-8.5 | E5-8,5 | POLARIZED CAPACITOR |
C12 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C13 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C14 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C15 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C16 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C17 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C18 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C19 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C20 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
C21 | 100u 10V | CPOL-EUE5-8.5 | E5-8,5 | POLARIZED CAPACITOR |
C22 | 100n | C-EU025_050-025X075 | C025_050-025X075 | CAPACITOR |
IC1 | PCA82C250 | PCA82C250 | DIL08 | CAN CONTROLLER INTERFACE |
J4 | SI-50170 | SI-50170 | SI-50170 | Ethernet Connector MagJack (R) |
J6 | SJ | SJ | SMD solder JUMPER | |
J7 | JP3Q | JP3Q | JUMPER | |
J12 | SJ | SJ | SMD solder JUMPER | |
J13A | SJ | SJ | SMD solder JUMPER | |
J13B | SJ | SJ | SMD solder JUMPER | |
J13C | SJ | SJ | SMD solder JUMPER | |
J15 | SJ | SJ | SMD solder JUMPER | |
J16 | JP3Q | JP3Q | JUMPER | |
J19 | SJ | SJ | SMD solder JUMPER | |
J20A | SJ | SJ | SMD solder JUMPER | |
J20B | SJ | SJ | SMD solder JUMPER | |
J20C | SJ | SJ | SMD solder JUMPER | |
J21 | SJ | SJ | SMD solder JUMPER | |
J22 | JP3Q | JP3Q | JUMPER | |
J25 | SJ | SJ | SMD solder JUMPER | |
J26A | SJ | SJ | SMD solder JUMPER | |
J26B | SJ | SJ | SMD solder JUMPER | |
J26C | SJ | SJ | SMD solder JUMPER | |
J27 | GMSTBA4 | GMSTBA4 | GMSTBA4 | PHOENIX |
J28 | JP2E | JP2 | JUMPER | |
J30 | SJ | SJ | SMD solder JUMPER | |
J31 | JP3Q | JP3Q | JUMPER | |
J35 | SJ | SJ | SMD solder JUMPER | |
J36A | SJ | SJ | SMD solder JUMPER | |
J36B | SJ | SJ | SMD solder JUMPER | |
J36C | SJ | SJ | SMD solder JUMPER | |
J40 | SJW | SJW | SMD solder JUMPER | |
J41 | JP2E | JP2 | JUMPER | |
J42 | JP2E | JP2 | JUMPER | |
JP2 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP10 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP14 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP29 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP34 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP37 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
JP39 | PINHD-1X04_2.54 | 1X04 | PIN HEADER | |
KIT1 | MBED_NXP_LPC1768 | MBED_NXP_LPC1768 | MBED-KIT | Mbed LPC1768 - ARM CORTEX v2.1 |
LED1 | LED3MM | LED3MM | LED | |
LED2 | LED3MM | LED3MM | LED | |
LED3 | LED3MM | LED3MM | LED | |
MOT_FEED | GMSTBA5 | GMSTBA5 | GMSTBA5 | PHOENIX |
OK1 | ILQ620 | ILQ620 | DIL16 | SIEMENS OPTO COUPLER |
OK2 | ILQ620 | ILQ620 | DIL16 | SIEMENS OPTO COUPLER |
POWER | GMSTBA4 | GMSTBA4 | GMSTBA4 | PHOENIX |
R1 | 120R | R-EU0207/2V | 0207/2V | RESISTOR |
R2 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R3 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R4 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R5 | 2k2 | R-EU0207/10 | 0207/10 | RESISTOR |
R6 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R7 | 2k2 | R-EU0207/10 | 0207/10 | RESISTOR |
R8 | 2k2 | R-EU0207/10 | 0207/10 | RESISTOR |
R9 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R10 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R11 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R12 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R13 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R14 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R15 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R16 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R17 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R18 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R19 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R20 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R21 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R22 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R23 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R24 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R25 | 10k | R-EU0207/10 | 0207/10 | RESISTOR |
R26 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R27 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R28 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R29 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R30 | 1k | R-EU0207/10 | 0207/10 | RESISTOR |
R31 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R32 | 330R | R-EU0207/10 | 0207/10 | RESISTOR |
R33 | 100 | R-EU0207/10 | 0207/10 | RESISTOR |
R34 | 100 | R-EU0207/10 | 0207/10 | RESISTOR |
T1 | BD647V | BD647V | TO220AV | NPN BIPOLAR DARLINGTON TRANSISTOR |
T2 | BD647V | BD647V | TO220AV | NPN BIPOLAR DARLINGTON TRANSISTOR |
U$1 | POLOLU_A4983CARRIER | POLOLU_A4983CARRIER | A4988BREAKOUT | |
U$2 | POLOLU_A4983CARRIER | POLOLU_A4983CARRIER | A4988BREAKOUT | |
U$3 | POLOLU_A4983CARRIER | POLOLU_A4983CARRIER | A4988BREAKOUT | |
U$5 | R-78B*-* | R-78B*-* | R-78B**-* | RECOM R-78B**-* switching regulator (78xx compatible) |
U$6 | POLOLU_A4983CARRIER | POLOLU_A4983CARRIER | A4988BREAKOUT | |
U4 | SD_CARD_SOCKETSD | SD_CARD_SOCKETSD | SD-MMC_SOCKET-PP | SD/MMC Socket |
U11 | SD_CARD_SOCKETSD | SD_CARD_SOCKETSD | SD-MMC_SOCKET-PP | SD/MMC Socket |
X1 | PN87520-S | PN87520-S | PN87520-S | BERG USB A connector (shielded) |
X2 | B5B-XHB | B5B-XHB | B5B-XH | XH CONNECTOR 2.5 mm, 5 pin 1 row |
X3 | B5B-XHB | B5B-XHB | B5B-XH | XH CONNECTOR 2.5 mm, 5 pin 1 row |
X4 | B5B-XHB | B5B-XHB | B5B-XH | XH CONNECTOR 2.5 mm, 5 pin 1 row |
X5 | B5B-XHB | B5B-XHB | B5B-XH | XH CONNECTOR 2.5 mm, 5 pin 1 row |
X6 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X7 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X8 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X9 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X10 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X11 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X12 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
X13 | B4B-XHB | B4B-XHB | B4B-XH | XH CONNECTOR 2.5 mm, 4 pin 1 row |
XMOT | GMSTBA5 | GMSTBA5 | GMSTBA5 | PHOENIX |
YMOT | GMSTBA5 | GMSTBA5 | GMSTBA5 | PHOENIX |
ZMOT | GMSTBA5 | GMSTBA5 | GMSTBA5 | PHOENIX |
