RevRadio
Versie door Bertrik Sikken (overleg | bijdragen) op 12 aug 2013 om 15:55 (Add rtlsdr.org link)
Project RevRadio
Contact User:Bertrik_Sikken
Last Update 2013-08-12
Roof is looking much better now
HF (0 - 30 MHz)
To receive signals from the relatively low frequency "HF" band, we have a ham-it-up board. The ham-it-up converts signals from 0-30 MHz up to 125-155 MHz, this makes is possible to use an RTL2832-based dongle to receive them.
  • morse and rtty beacons;
  • amateur radio voice;
  • amateur radio SSTV (slow-scan TV);
  • number stations such as the buzzer;
  • commercial AM broadcasts
  • etc.
Generic VHF/UHF (30 - 1700 MHz)
Still installing
For generic radio reception in the VHF/UHF bands, we have a setup consisting of a discone antenna (ICOM AH-7000) on the roof of RevSpace and an RTL2832 dongle (R820T tuner). A simple filter (1/4 wave open stub) has been built to suppress very strong pager signals.
  • Citizens Band radio, 27 MHz
  • 10 meter amateur band, 28-29.7 MHz
  • 4 meter amateur band, 70-70.5 MHz
  • broadcast FM stereo, 88-108 MHz;
  • air traffic (voice);
  • P2000 paging traffic at 169.650 MHz;
  • weather images from the NOAA-15/18/19 weather satellites, at around 137 MHz;
  • APRS traffic;
  • weather info from weather balloons, at 400-410 MHz;
  • ads-b/mode-s airplane transponders, at 1090 MHz
  • etc.
HAB tracker (434-435 MHz)
The colinear
For tracking high-altitude balloons, we have a setup consisting of a Diamond X-50N antenna on the roof of RevSpace, a so-called hab-amp (bandpass filter and 430-440 MHz LNA) and an RTL2832 dongle (FC0013 tuner). For more information, see the dedicated page at HAB_Tracker_Station
Currently one PC is dedicated to radio reception, called "habtracker". To start the PC:
  • Windows XP, hostname "habtracker", IP 10.42.44.94 (MAC 00:21:70:02:62:0f)
  • Start the machine with a magic WoL packet: 'wakeonlan -i 10.42.255.255 00:21:70:02:62:0f; ping habtracker'
Remote control
The PC can be remotely controlled as follows:
  • Teamviewer, ID: 675540724
  • VNC: geheim ;-)
TODO
Stuff we are still planning to do:
  • wait for proper cables for the ham-it-up
  • think about an antenna for HF
